Old 07-26-2004, 03:50 PM   #1
sbkim
Default HELP Trouble Shifting into First Gear
I belive it's normal for our cars to have some difficulty shifting into 1st and 2nd when the weather is cold but lately even during warm weather I am having slight difficulty getting it in the 1st gear. I have to somewhat force it into the gear and feels like something is either blocking or making it grind (notchy). Could I have a bad synchro? Or is this just normal?
Thank you
sbkim is offline   Reply With Quote
Old 07-26-2004, 03:58 PM   #2
Ulysses
Default Re: HELP Trouble Shifting into First Gear
Upshifting or downshifting?
Is the car sitting still or is it decelerating/accelerating?
Had any work done lately involving the tranny?
Could be a bent shift fork.
Old 07-26-2004, 05:12 PM   #3
Johann
Don't discount the possibility that the clutch isn't fully releasing.
Johann is offline   Reply With Quote
Old 07-26-2004, 06:46 PM   #4
kgrif
mine occassionally does it too. At light, completely stopped. Have to shift to 3rd or 4th and then back to first. A couple of times I have had to shift into 2nd and start out there, Did not want to force it!
kgrif is offline   Reply With Quote
Old 07-26-2004, 06:47 PM   #5
joe117
Bent fork or hydraulic problems. For some reason your clutch is dragging.
I don't think I ever heard that there was a problem shifting into gear when the car is cold.
joe117 is offline   Reply With Quote
Old 07-26-2004, 07:16 PM   #6
sbkim
This only occurs when the car is stopped. However, if I put the gear in reverse, it goes it very smoothly. It doesn't feel like the clutch. I can definitely feel something rubbing as I shift into 1st gear. Again, this does not happen all the time.
Thanks again for everyone's input
Old 07-26-2004, 08:37 PM   #7
Hisserman
Hisserman's Avatar
Sounds like the syncro . . .
Hisserman is offline   Reply With Quote
Old 07-26-2004, 08:47 PM   #8
got one
Central Texas VCA President
got one's Avatar
I have the same problem. As well sometimes I can't shift into second unless I get it past 1500rmp, or put in neutral and give it a wiggle then put it in second...can be quite embarassing when you are just taking off slowly at a light. But then again...it's a Viper, what am I doing taking off slowly at a light
Old 07-26-2004, 08:53 PM   #9
sbkim
Bruce - wouldn't bad synchro pretty much prevent you from shifting into that particular gear? I just came back from another drive and the car drives fine - ie. shifts easily into 1st but i know it will come back. Is it possible that certain parts of the synchro may be bad?
Old 07-26-2004, 08:53 PM   #10
Hisserman
Hisserman's Avatar
qotone --
Your problem is built into the transmission. There is a by-pass that forces a shift from 1st to 4th if you start out slowly. They say it "saves gas mileage" -- whatever! As you have found out you can avoid the by-pass by revving over 1500 rpm. Aftermarket suppliers carry a "skip shift eliminator" you can install and make the problem go away.
Old 07-26-2004, 08:59 PM   #11
Hisserman
Hisserman's Avatar
Sometimes certain teeth on the synchro can be dammaged -- from power shifting, or whatever. I think you should have your tech look at it before it gets worse.
These transmissions are well tested and generally bullet proof. Parts are easy to get. Get it checked out.
Old 07-26-2004, 10:05 PM   #12
got one
got one's Avatar
Thanks Bruce!
Old 07-27-2004, 05:50 AM   #13
joe117
If it were the dragging clutch, as I thought, your worst condition would be the shift into reverse. No synchros in reverse.
I'd say the problems you have are in the trans.
Old 08-02-2004, 07:05 PM   #14
sbkim
Update - took it to the dealership and had one of the tranny guys drive the car. Verdict - it's normal. ha, what's new.
Anyway, I am thinking about changing out the fluid to see if that helps. I doubt it as the trouble I am having - comes and goes - is that while shifting to 1st from a deadstop, it feels like I am catching something and then you have to force it through to properly engage in 1st. If anyone has any other suggestion, I am all ears...
Old 08-02-2004, 07:43 PM   #15
2BADD 4U
sbkim
I have exactly the same problem as you. I also had the exact same problem with my C5 Vette. It is normal, as the chevy dealer told me. It does not happen all the time, and ONLY happens at a dead stop..at a red lite. If you are moving slowly thru a stop sign(California Slide)...it goes into first everytime. But at a COMPLETE stop it does hang up..But only maybe 1 out of 4-5 times or so. Nothing to worry about. Solution is to shift from 3-4 and 2nd, and into 1st. I was told by the dealer that sometimes the gears and syncros do not align up 100% of the time at a stop and it is normal.
I have learned to live with it and it is not a big problem. If the tranny locks up, or gets stuck in a gear, or grinds...well then that is a problem, and I will get a new one under my warranty. Keep driving and enjoying your great Viper.
Dave
2BADD 4U is offline   Reply With Quote
missing a gear while shifting Marcus General Viper Discussion 15 06-19-2008 03:41 PM
Shifting in 1st gear JiPi RT/10 and GTS Discussions 3 10-17-2005 11:50 AM
Trouble with third gear ViperJon RT/10 and GTS Discussions 2 04-26-2005 09:11 PM
Trouble shifting to third BYT U L8R RT/10 and GTS Discussions 4 07-01-2003 06:44 PM
Noise when shifting in first and second gear, '94. JonB - PartsRack RT/10 and GTS Discussions 0 08-03-2002 12:19 AM
