Old 10-29-2004, 11:11 AM   #1
EA6BPilot
Default Wiring harness for radio replacement????
I was wondering if anyone knows if they make a wiring harness for a Gen II to replace the factory radio. I don't want to have to splice into the car's harness if I can avoid it.
Also, do they make a harness to join the amp's inputs to the outputs (so you can bypass the amp altogether)? I know it is standard on most vehicles, but I'm having trouble finding one for a Viper. Thanks!
Frank
EA6BPilot is offline   Reply With Quote
Old 10-29-2004, 12:19 PM   #2
tommygun
Default Re: Wiring harness for radio replacement????
Contact Alpine stereos, they should have the info you need as it is an Alpine unit.
tommygun is offline   Reply With Quote
Old 10-29-2004, 07:51 PM   #3
ruckdr
WA VCA Member
ruckdr's Avatar
Any stereo installation place (Car Toys, Crutchfield, you know the one around the corner from you (so to speak).....)will have a plug to plug into the Viper connectors with bare wires, which you splice to the bare wires from the new radio head you buy. Very simple I did it, and still used the line outs (RCA plugs)to the stock amps in the trunk. I put in the Panasonic CQ-C1300U which plays MP3, regular CD's, and WMA CD's.
Now, having said that, chances are all (I say cautiously)after market heads will have the same colored wires coming out of their connector. You only need 4 wires as follows:
BLACK - ground;
YELLOW - Battery +12V:
RED - Accessory (+12V with ignition switch on);
DARK BLUE/WHITE STRIPE - to relay to power amps in the trunk.
No speaker connections necessary since the line outs go to the amps which send to the speakers.
You will appreciate vastly improved sound, regardless of which aftermarket deck you put in.
Good luck,
Later,
ruckdr is offline   Reply With Quote
Old 10-30-2004, 01:30 AM   #4
EA6BPilot
Don,
Thanks for the info. I've done several car stereo installs, so it won't be a problem. That "shop around the corner from me" couldn't find a harness for a Viper, so I was wondering if he was screwed up or if they didn't make one. I will do some more looking online. I appreciate the help.
Frank
Old 10-30-2004, 09:11 PM   #5
Jack B
Jack B's Avatar
I think you are going to have a difficult time finding a plug and play interface connector. I recently put in an after-market system. The high end receivers are a bit deeper than the oem unit, the problem that the splicing creates is the added bulk which is hard to fit behind the increased depth receiver. You also have to splice the pre-amp outs. When and if you start splicing make sure the splices are compact and do not take up much volume. If you can find an interface connectos it will save a lot of grief.
wiring harness needed vettekiller RT/10 and GTS Discussions 4 02-25-2006 09:14 AM
Advice on door wiring harness. 747Capt RT/10 and GTS Discussions 1 04-23-2005 08:04 AM
Looking for Gen II wiring harness Vip-RT10 RT/10 and GTS Discussions 1 10-24-2002 08:26 PM
Looking for Gen 2 wiring harness Maverick The Electrician Sneaky Pete's Place 1 02-15-2002 08:56 PM
Stock wiring alpine harness Ulysses Archive Management 6 05-28-2001 01:07 PM
