Old 11-11-2004, 11:17 AM   #1
MoparMan
Default Roller rocker install question
Our local Viper tech was saying that he thought the Mopar roller rockers were more than a simple bolt on install. He was saying he thought there was work to be done to the heads themselves to install the rockers. When I installed rockers on my Dak R/Ts 360 it was a simple bolt on. Isn't that the case with the Viper's V-10 as well?
MoparMan is offline   Reply With Quote
Old 11-11-2004, 11:35 AM   #2
99 R/T 10
99 R/T 10's Avatar
Default Re: Roller rocker install question
The instructions state to remove the heads and mill down the rocker stands. You DO NOT have to do this. Simply get a longer pushrod that makes the correct geometry for the set up. Most us 7.65-7.70" one piece pushrod. You can get a set from either Jegs or Summtracing for around $100 a set. Have you tech call either Larry Macedo or Chuck Tator, they will help him out over the phone.
Old 11-11-2004, 11:37 AM   #3
JimT 99RT
With the correct length push rods the Mopar (T&D Brand) rockers are bolt on. The valve covers have to be modified slightly for clearance. I watched the install but did not do it myself.
JimT 99RT is offline   Reply With Quote
Old 11-11-2004, 11:59 AM   #4
MoparMan
Thanks for the info! So, should the pushrod length be 7.65 or 7.70?
On the mod to the valve covers is it just a matter of dimpling the oil baffle in the top of the cover as on the 360 Magnum engine?
Old 11-11-2004, 12:08 PM   #5
99 R/T 10
99 R/T 10's Avatar
Depends on the car. Why, I don't know, but some use 7.65(mine did). Most used 7.70.
Old 11-11-2004, 12:08 PM   #6
Simms
Simms's Avatar
Get yourself an adjustable pushrod to double check which length you need.
Simms is offline   Reply With Quote
Old 11-11-2004, 01:20 PM   #7
MoparMan
...or just install a complete set of adjustables?
Old 11-11-2004, 01:57 PM   #8
Simms
Simms's Avatar
Adjustable pushrods are not real pushrods. They are just used to take a measurement.
Old 11-11-2004, 03:33 PM   #9
txlen
if you do jesel rockers they come with an adjustable pushrod so you can figre out the correct length and order the right length pushrods for your application...Len
txlen is offline   Reply With Quote
Old 11-11-2004, 04:53 PM   #10
MoparMan
duh...sorry for the stupidity! I never had to replace the push rods the one time I changed the rockers.
Does anyone know the correct length for the push rods for a '00 Viper engine with the Mopar roller rockers? I'd like to avoid leaving the car with the tech while the rods get ordered and shipped.
Old 11-11-2004, 05:08 PM   #11
HSSSTOY
VCA President Ontario
HSSSTOY's Avatar
The other way is to shave the screw knobs approx. 8mm before installing the oil baffles back on. Have some one with experience do the RR, and you will enjoy the extra hp.
HSSSTOY is offline   Reply With Quote
Old 11-11-2004, 05:55 PM   #12
SingleMalt
It really is best to measure the pushrod length on your engine, regardless of what others with the same engine have used. Like Mike said, the length his car required weren't the norm.
Mike
SingleMalt is offline   Reply With Quote
Old 11-11-2004, 10:50 PM   #13
Jack B
Jack B's Avatar
Don't take a short cut, this is a two part process. You HAVE to measure the push rod length first. The sweet spot on the Mopar/T&D's is only about a .050 range. The max down is two full turns which is .100. DO NOT go below two full turns down or you will have problems. Have your tech measure the push rod and have Summit do next day air, they will have the push rods in stock.
Old 11-11-2004, 11:04 PM   #14
Daniel Cragin/DC Performance Inc
Pushrod length may vary quite a bit between engines, it depends on the base circle of the cam and the valve installed height. We have five different sizes we use. Many performance heads have a longer valve which requires raising the shafts and running a even longer pushrod.
Daniel Cragin/DC Performance Inc is offline   Reply With Quote
Old 11-11-2004, 11:16 PM   #15
99 R/T 10
99 R/T 10's Avatar
Hey Jack or Daniel Cragin,
I remember a post a while back that stated if the pushrod was sunk in to it's deepest point(safely) there was a larger pickup in HP. Any truth to that, anybody?
Jesel 1.7:1 Rocker Arm Install Question Purdue_Boiler_Viper RT/10 and GTS Discussions 2 02-02-2006 08:09 AM
Roller Rocker Install DIY, Top Dead Center??? bwhitmore RT/10 and GTS Discussions 10 01-01-2005 09:43 AM
T&D Roller Rocker installation tips ??? Dixter RT/10 and GTS Discussions 8 08-11-2003 11:13 PM
Roller-Rocker Question /Oil Pan Question Viper Specialty RT/10 and GTS Discussions 21 01-12-2003 01:25 PM
Roller rocker rods Snakester Performance Modifications 6 06-26-2002 05:53 PM
