Old 12-17-2004, 02:47 AM   #1
RIch
Default Sway Bar Question
I have heard that the early Vipers were very neutral handling (slight oversteer) when pushed to the limit. I also hear that the 96 and newer Vipers have a tendency to understeer (push) at the limit. Has anyone had experience with sway bar changes that cured the understeer tendencies of a 96 GTS?
RIch is offline   Reply With Quote
Old 12-17-2004, 08:09 AM   #2
2002_Viper_GTS_ACR
NorCal VCA Member
2002_Viper_GTS_ACR's Avatar
Default Re: Sway Bar Question
Understeer ?? hmmm.. my car does nothing but OVERsteer. I have an acr, but I have a feeling that most vipers oversteer (meaning the rear will come around on them before the front stops pulling into the turn). Understeer I think would be a better situtation, you could at least always count on the rear staying where it should, instead of coming around to say hi.
Jon
Old 12-17-2004, 03:30 PM   #3
onerareviper
Jon,
Ditto...
Old 12-17-2004, 05:29 PM   #4
ViperRay
On a road course, the Gen II's at least tend to understeer (push) when cornering. You can certainly use the throttle to bring the rear around if you want but I prefer a car more under control.
Woodhouse (and others I presume) sell an adjustable front sway bar which allows you to soften the front a little to help with this.
I have one...with all the suspension changes I've made though I can't tell the contribution from this one mod but car corners much better now.
ViperRay is offline   Reply With Quote
Sway-bar links or new aftermarket sway-bars? Ray W RT/10 and GTS Discussions 2 11-07-2006 12:17 AM
Sway Bar dia? V10 ACR RT/10 and GTS Discussions 1 12-02-2004 06:48 PM
Dumb sway bar question Bonkers RT/10 and GTS Discussions 4 04-28-2004 08:49 AM
Front sway bar Viperoctane RT/10 and GTS Discussions 8 10-21-2002 07:10 AM
Sway Bars Tom, F&L GoR Performance Modifications 2 12-05-2000 11:22 AM
