Old 12-22-2004, 01:09 PM   #1
twinvipers
Default what is the stickiest 19\" rear tire ?
What 19" rears will stick the best. Don't care about tread life. Anyone know of 19" drag radials coming out ?
twinvipers is offline   Reply With Quote
Old 12-22-2004, 02:31 PM   #2
Martin2000GTS
Default Re: what is the stickiest 19\" rear tire ?
I also would like to know as well if there are and 19x345mm out there. After getting 3.73's installed next spring ill need them.
Martin
Martin2000GTS is online now   Reply With Quote
Old 12-22-2004, 06:54 PM   #3
Go Fast For Life
Go Fast For Life's Avatar
Doesn't the comp coup come with 19" slicks? Who makes those?
Go Fast For Life is offline   Reply With Quote
Old 12-22-2004, 07:57 PM   #4
RedGTS
The short answer is there are no good options. It's pretty much Pilots or Pirelli's, and neither is anywhere near as sticky as Kumho V700's or a drag radial like the BFG. The comp coupe uses 18" rear tires, unlike the SRT-10.
RedGTS is offline   Reply With Quote
Old 12-23-2004, 09:38 AM   #5
twinvipers
Someone has to be working on 19" drag radials...
Old 12-23-2004, 10:46 PM   #6
PhoenixGTS
Found this news item on the Kumho site regarding the re-release of the V710. It says the v710 is currently available in 7 sizes, but will be available in 17 sizes soon. Could 345-19-25/30 be one of the upcoming sizes? Hopefully. Heck I live in the desert, I'd run slicks for sure if they cam in 19".
http://www.kumhousa.com/V710.asp
Old 12-28-2004, 10:00 AM   #7
twinvipers
Are they making it in 19 ?
Rear noise from my tire 98viperGTS RT/10 and GTS Discussions 3 10-02-2004 07:30 PM
Whats the stickiest tire available in a 345/30/19 ?? Yellow Fever RT/10 and GTS Discussions 7 03-06-2004 01:00 AM
Anyone have a used rear 17" MMX3 tire? Achilles99 RT/10 and GTS Discussions 3 03-03-2004 03:58 PM
rear tire question?? VIPER1996 RT/10 and GTS Discussions 3 10-31-2003 02:55 PM
Viper Front->Rear Weight ratio, lbs/in rear tire traction, etc Frank Parise RT/10 and GTS Discussions 0 11-21-2001 09:55 AM
