Old 02-20-2005, 01:19 PM   #1
carl B
Default seem to have fixed the idle hang
Fitted a Roe performance PCM today and no idle hang today!!??
Carl
carl B is offline   Reply With Quote
Old 02-20-2005, 01:25 PM   #2
Ulysses
Default Re: seem to have fixed the idle hang
Let the PCM learn for a few drive cycles before you declare the problem fixed.
Old 02-20-2005, 01:29 PM   #3
carl B
point taken!
Carl
Old 02-20-2005, 02:55 PM   #4
Shelby3
Shelby3's Avatar
I had the same experience. Idle hang returned. As the memory fills up with error codes it might return. Clear the memory and it will go away for a time. That is how mine is working.
Shelby3 is offline   Reply With Quote
Old 02-20-2005, 09:46 PM   #5
PhoenixGTS
Since I try to post on every idle hang thread, just wanted to mention that John Horton the master Viper tech since 1992 that runs West Coast Viper swears that the secret to killing idle hang is to run the Number Four test, the idle air pass test, on the DRB diagnostics tool the dealer has so that the throttle bodies are perfectly synchronized. My understanding is that you hook up some leads to vacuum lines on the throttle bodies and the machine ends up electronically monitoring how much air is passing over each throttle plate at idle so that you can match them via real air flow rather than mechanically comparing the angle of the two plates at idle. I am going to throw in some guaze filters then get this test done and will be reporting the result.
And oh yeah, weight 50 or so miles before you declare your idle hang dead.
Old 02-22-2005, 09:42 AM   #6
V10BAT
phoenixGTS hi i thought there was no air going past the throttle plates at idle.?? ie plates closed.the only air going into the motor coming from the iac motor?if air is going over the plates at idle could i connect a vacuum gauge to the two small ports on the manifold just behind the throttle bodies,and then adjust the plates????. i don`t think anyone in the uk has a drb tool.but i bet they got hang.ps i am new please forgive me if i am being a t*t.
lets get this beat.looking forward to your test results
DAVE.UK
V10BAT is offline   Reply With Quote
Old 02-22-2005, 10:51 PM   #7
Jack B
Jack B's Avatar
I do not have idle hang, however, when I removed the manifold last year and the throttle assembly must have taken a physical hit. The result was a stumble at about 2000 rpm's. I did not associate it with the throttle sync at the time. I finally narrowed it down (after six months) to the throttle sync issue. I now have it very close, but, not exact and I can attest it is not easy to eyeball and adjust the throttle bodies.
Old 02-22-2005, 10:57 PM   #8
Gerald
by the way, mines still gone for the nay sayers..
that is all
thank you
Gerald
Gerald is offline   Reply With Quote
Old 02-22-2005, 10:58 PM   #9
Gerald
Carl
btw, it's not software related. I think it'll come back once the car relearns the parameters with the new PCM.. but I hope for your sake it works!!
G
Old 02-23-2005, 08:47 AM   #10
PhoenixGTS
DAVE.UK
According to Mr. Horton (and I believe him), the butterfly plates allow air past even when closed all the way. He even suggested that if I had the throttle bodies off, I should hold them up to the light and could probably see if one is a bit more open than the other when they are supposedly "closed," but maybe a better description would be how well the round butterfly plate fills up the round throttle body channel. Given a little bit of "leak," then the IAC can open and close to finely adjust the amount of idle air. Just repeating what I heard.
P.S. embarassed about using "weight" in place of "wait" in my post above.
Old 03-10-2005, 01:46 AM   #11
carl B
well its a while now and it has not come back??
Carl
Old 03-10-2005, 10:15 AM   #12
Ulysses
Idle Hang-Never ending. Dowl in Idle Air Motor hose? ntsi RT/10 and GTS Discussions 0 05-01-2005 10:25 PM
My idle hang is finally fixed!!! Fully gone and not by resetting the PCM. Falconeer RT/10 and GTS Discussions 3 04-23-2005 08:46 PM
No more idle hang! Gerald RT/10 and GTS Discussions 3 05-30-2003 11:15 AM
*** My Idle Hang... FIXED!!**** Gerald RT/10 and GTS Discussions 6 05-29-2003 09:08 AM
Idle Hang kowalski vanishing point RT/10 and GTS Discussions 29 07-16-2002 08:23 AM
