Old 04-05-2005, 06:02 AM   #1
Tom, F&L GoR
Tom, F&L GoR's Avatar
Default Fuel line check valves shipping out... (no more crank, crank, crank)
The first batch of fuel line check valves (hereafter known as "HeadStart" valves) are done and will be sent today/tomorrow. With 2-day USPS you should get them by the end of the week.
I need some help. Does anyone have an image of the fuel pressure relief valve if it is not located on the passenger side, top rear of the intake manifold? My '94 service manual has a B/W drawing showing it on the end of the driver's side manifold, but it's not clear since it shows both a cap and a nipple at the same time. In looking for images, it seems that three rib manifolds have the valve up top, while four rib manifolds must have them in the back.
To all you first-batch testers, please comment on the written instructions, let me know how you make out, particularly with keeping the fuel off you, your driveway, etc. Thanks.
First post
rwhp = how much at the crank? RikRok RT/10 and GTS Discussions 9 12-22-2006 01:15 PM
Taking off Crank Damper....which way does the crank bolt turn to take off? ab RT/10 and GTS Discussions 7 05-25-2005 10:15 PM
keying the crank...... ab RT/10 and GTS Discussions 6 06-20-2004 08:25 AM
If your Viper is out of warranty, check your crank hub bolt torque.... Sean Roe RT/10 and GTS Discussions 8 05-19-2004 07:59 AM
Crank & Harmonic balancer/crank pulley have come disconnected?? HELP!! MKB96Viper RT/10 and GTS Discussions 3 04-27-2004 07:59 PM
