Old 04-07-2005, 08:27 PM   #31
Marv S
VCA Western Zone Director
Default Re: Roe S/C with Belanger headers VS B&B headers: Graph inside
Tri-Y headers have been around for a long time.
They were used on small blocks and less on big blocks.
The pitch was the same then as it is now - tri-y had smaller tubes and gave the benefit of increasing low end power - a good thing for the small block.
The merge collector exhausts used larger tubes and had higher flow rates. Result was more power at the top end with a lot of air moving but a bit less power in the mid range than a smaller tube tri-y.
You might conclude that for stock Viper with those small block holes that a tri-y has a benefit in the mid over a merge. But that the merge will flow more air at the high rpm use or forced air conditions.
Marv S is offline   Reply With Quote
Old 04-07-2005, 08:48 PM   #32
Mr Hemi Head
Mr Hemi Head's Avatar
It appears that B&B make a 5 into 1 and Tri Y, which ones gave the performance boost?
Mr Hemi Head is offline   Reply With Quote
Old 04-07-2005, 09:34 PM   #33
DSR207
It's gone for no reason...Here it is again David Weaver's before and after dyno graph
DSR207 is offline   Reply With Quote
Old 04-08-2005, 12:01 AM   #34
KenH
KenH's Avatar
I guess the one thing that doesn't seem to add up to me is why there would be a relatively even gain across the whole RPM range. If the header is a restriction at the higher flow rates, you would expect to see near equal performance at lower RPMs and then the higher flowing header would pull away from the lower flowing header when it started to become a restriction somewhere in the higher RPM range.
Makes me wonder if there isn't some other factor at play.
New Belanger Headers JoeB RT/10 and GTS Discussions 12 04-17-2008 08:44 AM
Belanger Headers and FI?? Bonkers RT/10 and GTS Discussions 1 06-17-2006 10:26 AM
Anyone looking for a set of Belanger Headers? Casey RT/10 and GTS Discussions 16 02-21-2005 09:25 PM
Belanger Headers and S/C Larry Macedo RT/10 and GTS Discussions 40 10-28-2004 09:46 AM
SRT-10 and VCC Belanger Headers JonB - PartsRack New Products, Supplier Specials, and Group Buys 5 05-26-2004 10:33 PM
