how much of a boost can i go on a roe SC? if pistons are changed can i go 10lbs or more? do i need to change somehting else? would a 10lbs pulley give me 800 rwhp or more?
from what I have seen, I don't think just the 10lb pulley will give you 800 hp...maybe at the fly wheel...but not rear wheel. I think maybe low to mid 700 without any power adders...but I reserve the right to be wrong..just basing this off the people I know who have 10lb'ers
I know Tony is making impressive power with his roe set up. |
Tony can cook a banquet with his set-up. less than 800rwhp (not by much), he runs water, meth, propane, and supercharger. There is probably some canola oil in there too somewhere.
to get to 800rwhp, you really need some head work. and since you'll have to take the heads off to get to the pistons anyway, send them out to Greg Good for a stage III port job. when they come back, they will flow 30-40% more air and that 10lb pulley will actually only be pushing 7lb anyway. come to think of it, i don't know of anyone that has done a ROE with some serious headwork. Cudaman maybe... but he also runs NOS. And he also runs 9.x like Tony... just bumping up the boost, though, (even if the car could handle it) won't get you to 800rwhp. with meth injection, it will help but even if you use the 30hp/psi rule of thumb (which it really isn't), then you add 150hp. to where you are now + meth inj to add 25-50, maybe... could happen, perhaps. not sure. it's late... don't hold me to this. Except the part about the canola oil. JD |
Well all I know is when I run out of propane...I just hook up to tony's car and BBQ time it is! Yummy!
thanks Ab and Joseph. very hepful so far. so heads and 10lbs would give me 700rwhp?
more than likely, yes. but keep in mind that 10lb isn't 10lb once heads are done. so you could, conceivably, go to an even smaller pulley (call Sean about pully sizing). since the heads flow more, there is less pressure which means that what was once 10lb is actually 6 or 7 or 8.
let's make up some #'s here to articulate this. stock heads (let's say they flow 235 cfm @ .600 lift) + 5psi ROE = 550rwhp. port heads but keep SC pulley the same = 3.5 or 5psi of boost, but 590 or 600rwhp ! port heads and bump boost back up a litle (use a 7lb pulley which will yield 5psi on this combo) and you might be at 630 or 650rwhp. get the gist so far? most boost does NOT [necessarily] = more power... good luck! JD |
#7 | |
#8 | |
My Roe has a 10# pulley, (Ross pistons), tuned by Macedo and I am pulling 626 hp rear wheels, 697 torque. Adding the meth injection has not seemed to add any seat of the pants feel but I am sure I am running safer. Stock heads, B&B etc. I don't think you will get to 800 RWHP by just adding heads to the package. I think that many cars may be run on optomistic dynos with some of the numbers I have seen (what do you think Sun Ra Kat)
Vipr GTS: with water meth you can up the boost to a 12 pully right?
STUGOTS: I have not talked to Larry or Sean about that. I would think that heads and cam would be more in order now sp that I can utilize all of that pressure.
#12 | |
With a 10lb pulley, heads/cam, we upgraded my pump anyway for added security. |
I think Sunkarat is running 740 rwhp?
#14 | |
sometimes Kenney's licesnse plate changes with each tank of gas. I really don't know if Kenney has even been on a dyno, at least in the last couple of years.
Dimitrios,
From what I understand forged pistons and 10psi on your car would give you ~630wheel. With stock heads the increased boost will not give you as much as you would think as the heads turn into the bottleneck. If you add water injection and some good tuning to your 10psi you could hit 650. To hit 700 you would need some serious head work on top of that. IMHO low 700’s is about the limit on ROE blower alone without throwing the kitchen sink under the hood. |
dimitrios is right on, I dyno'e 626 rwhp with that set up and 697 torque. adding 20 hp and 30 torque is all that should be expected, stock heads just don't flow enough to force it to 700 hp
#18 | ||
LOL!!! Every time he dyno's it goes up 100hp. |
2MANY: you know Kenny well. He really is a nice guy but his HP numbers are suspect at best.
#20 | |
Cudaman |
#21 |
My question, has any one that has installed the ROE unit in the last 6 months with a 5 lb pully done a dyno on ther car, I know there were some problems with the first group of superchargers and The PCM programs were changed to correct the problems, I have looked at his web site and all he has for the GEN 2 cars are showing an 8lb pully. My car has Headers, HFC, Corsa exhaust, Tubes and K&n filters 355 gears. any one got any ideas, the best I can come up with is 530 hp & 600 TQ at the rear wheels
#22 | |
With my previous setup I had a 5lb roe, t&d rockers, hiflow cats, corsa, 70mm throttle bodies, airbox, etc.... I dynoed 581hp with 596tq mild tune in august over 100 degrees outside. I now have a custom paxton setup and am north of 1000hp |
#23 |
Sounds like thoes no.with a 5 lb pully are right on target with you bolt ons you have. I take it you changed pistons when you went with the Paxton.
#24 | |
#25 | |
Yea I'm not a creampuff anymore. Pistons were changed. |
#26 |
Brian ......I wouldn't let them call me a creampuff either.
Cudaman |
#27 | |
lol!! We're both decreampuffed! |
| Get more boost from your Roe Blower! | David Weaver | RT/10 and GTS Discussions | 337 | 03-20-2007 03:47 PM |
| Paxton with boost gage, what's your max boost? | Viper X | SRT10 and SRT10 Coupe Discussions | 5 | 11-30-2005 08:36 PM |
| Boost Guage For Roe SC | Dimitrios | RT/10 and GTS Discussions | 7 | 09-06-2005 05:22 PM |
| How Much Boost Can I Go? | Dimitrios | RT/10 and GTS Discussions | 11 | 08-22-2005 03:27 PM |
| How much boost? | Projecting IMAX 70mm | RT/10 and GTS Discussions | 1 | 05-08-2003 07:49 AM |
