Old 04-22-2005, 10:48 PM   #1
747Capt
AZ VCA Member
Default Advice on door wiring harness.
Has anybody replaced the driver door wiring harness? How big a job is it and is the harness avalible from Dodge? First mirror, then outside door release, inside door release, all quit in that order. Now door speakers intermittent. apparently not an uncommon problem on 2000 RT/10. Would like to avoid what could be a large installation charge as car is out of warranty. Any advice would be appreciated.
747Capt is offline   Reply With Quote
Old 04-23-2005, 07:04 AM   #2
Schulmann
VCA Regional President Quebec
Schulmann's Avatar
Default Re: Advice on door wiring harness.
I have an ACR and I had to rewire everything for a custom stereo. It can be done but requires to remove nearly everything from the door. As far as I remember likely you can keep the glass in place but you will have to remove the door. All depends on who is doing the job ... and you need space and time that's it.
Need Advice Re Wiring Harness that Attaches to Rear View Mirror Richard H. Vitale RT/10 and GTS Discussions 3 10-17-2006 12:18 PM
Door wiring harness - are later replacements any stronger? Randy RT/10 and GTS Discussions 26 09-19-2006 05:30 PM
Lost a door speaker? Door button inop? How to fix your door loom wiring. Vic RT/10 and GTS Discussions 11 04-13-2006 10:06 AM
My solution for Wiring harness problems in Door Jamb BLWNASP RT/10 and GTS Discussions 4 11-18-2005 01:35 PM
ANYONE HAVE A SPARE DRIVER DOOR WIRING HARNESS? 01bee RT/10 and GTS Discussions 4 02-16-2005 09:40 AM
