Old 05-03-2005, 04:36 PM   #1
Steve 02/RT10
Default Replacement of alpine head
What is the best fitting replacemnet head for quality and fit?
Steve 02/RT10 is offline   Reply With Quote
Old 05-03-2005, 05:01 PM   #2
Randy
Randy's Avatar
Default Re: Replacement of alpine head
I'm not sure there is a "best". I've put two different head units in Vipers - an Alpine CDA7897 (CD/MP3/AM/FM with auto-hiding faceplate) in my old '95, and a Pioneer AVIC-N1 (CD/MP3/DVD/AM/FM GPS nav system) in my '00. Both fit fine.
Other than the standard size opening, the only issue you'll really come across is depth of the unit and the mounts. I think the depth of the dash in '95 and '00 is plenty for all units. And, if you use the mounting "ears" from your stock unit and the appropriate "post" on the center of the rear of the unit, most should work fine.
If in doubt, just pull your stock unit out - in only takes about 1 minute - just carefully pull the surround bezel out (which is snapped in), being careful to not let the metal snaps on the underside of the bezel scrape against your dash, current head unit, or anything else you don't want scratched; then remove the two screws holding the stock unit in and pull it out.
Then, go shopping for what features you want - easiest is to look through Crutchfield, then when you find one you like and verify the dimensions match the stock unit (or shorter depth), then do a google search for the model number to get the best price.
Old 05-03-2005, 05:09 PM   #3
Steve 02/RT10
Thanks for the good info.
Old 05-05-2005, 06:23 AM   #4
Steve 02/RT10
Im going to upgrade to a CDA 9851 . I hear 2 different stories of what needs to be done. First they tell me a wire harness and install unit. 2nd they tell me I have to rewire to the factory amp. Anyone done it without rewiring to amp?
Old 05-05-2005, 09:18 AM   #5
Ray W
Ray W's Avatar
pm sent
Ray W is offline   Reply With Quote
Old 05-05-2005, 11:14 AM   #6
Ron
Ron's Avatar
Curious about same. WIll stock harness work and if not are there adaptors that prevent butchering
Old 05-05-2005, 12:38 PM   #7
Steve 02/RT10
Just purchased a wire harness that plugs into factory plug and all you have to do is wire it to new head. To change back to stock radio unplug harness and plug radio back into factory plug.
Old 05-05-2005, 03:03 PM   #8
Dv8tor
What/where did you get this? I'm going to replace my head unit with an Alpine CDA-9855 and a 12 CD changer and amp. A local installer says he'll need to chop the wire harness and the stock head unit can't be used again. I need to be able to put the stock unit back in. I even called Apline and they told me the wire harness must be cut for it to work correctly.
Dv8tor is offline   Reply With Quote
Old 05-05-2005, 03:54 PM   #9
Cal Cobra
Randy I just bought a clean 96' RT/10, and am considering either getting an Alpine CD m-bus changer to keep it stock, or going non-stock and getting the Pioneer AVIC-N1.
What are you thoughts on the AVIC-N1? Did you install it yourself or ? Did you get all the features going (GPS nav, digital dashboard, etc?)?
Thanks,
Cal
Cal Cobra is offline   Reply With Quote
Old 05-05-2005, 05:10 PM   #10
Steve 02/RT10
Sound Advise in Ft. Lauderdale. The one in Boca was out but can order one. Cost is $15 DOLLARS.
Old 05-05-2005, 05:25 PM   #11
Wayne
No splicing at all?
phone #?
Wayne is offline   Reply With Quote
Old 05-05-2005, 05:46 PM   #12
Randy
Randy's Avatar
Cal,
Yes, I did the install myself - took about 8 hours, plus an hour of prep work ahead of time making a DIN-to-RCA converter for the amp inputs, so I didn't have to cut/splice any of the factory wiring (other than the power/ground/dash lights) - now, even if you get an M-bus Alpine unit, I think you still have to make a converter for the DIN/RCA. I located the remote unit under the driver's seat. Only thing I didn't connect was the back-up light lead, which is part of the GPS nav, but I didn't think it was worth the trouble (to find the lead going to the rear of the car), and after almost a year of use I've not seen any problem from not connecting it. Everything works fine.
However, I don't know if they still sell the AVIC-N1, as they've come out with a successor unit, the AVIC-N2. I don't know anything about the N2, other than some discussion about not being able to override the DVD/car-in-motion-disable. Probably not a concern to most, but the N1 used a lead going to the parking-brake switch to decide whether you could watch DVD's on the screen; so, unless the parking brake lead was grounded (which is what happens when you have the parking brake engaged), no DVD viewing. The N2 reportedly uses the GPS to determine DVD viewing - if it senses motion, no DVD viewing, and there is no way to override this.
Of course the driver has no business watching DVDs while driving, and its against the law in most/all places to have something like that running in sight of the driver, but for those that have the self control to not be distracted by something like that, with the N1 they could decide whether or not to let the passenger watch DVDs. Like I said, probably not a concern to most.
Old 05-05-2005, 09:40 PM   #13
Dv8tor
How funny. I went to sound advise in Boca and there the ones who told me I had to cut my wires. ARRGG!!
Old 05-06-2005, 10:37 AM   #14
Matthew Klinger
anyone have any pictures?
Matthew Klinger is offline   Reply With Quote
Old 05-06-2005, 03:20 PM   #15
Steve 02/RT10
I removed my radio today to install new head. I found out that the salesman that sold me the harness was good at what he does (sells things). The harness and what he told me were false. To install new head you must splice wires. Sorry for the bad info.
Good luck
What is the best all in one Alpine head unit with display out there? ab Sneaky Pete's Place 0 02-05-2007 09:25 PM
anyone have a stock gen 2 alpine head unit SuperSaiks RT/10 and GTS Discussions 6 10-18-2006 11:07 AM
ALPINE FRIED replacement suggestions Jcoopacr2000 RT/10 and GTS Discussions 14 05-09-2006 01:51 AM
Is anything needed to wire alpine head unit to factory amps? Gottaviper RT/10 and GTS Discussions 2 03-15-2006 04:33 PM
Head Gasket replacement question. phiebert Archive Management 0 01-25-2001 07:30 PM
