Old 05-09-2005, 07:50 PM   #1
4207henri
Default split sec?
Can it tune a supercharger well enough or is it worth it to go ahead a buy a VECII or AEM?
4207henri is offline   Reply With Quote
Old 05-09-2005, 08:57 PM   #2
VIPER D
VIPER D's Avatar
Default Re: split sec?
vec 2 all the way.
vd..
VIPER D is offline   Reply With Quote
Old 05-09-2005, 09:05 PM   #3
Casey
Casey's Avatar
1--AEM---Best Out
2--VEC 2--works great, but it ain't the AEM
3--Split Second--works well for SC setup.
AEM, won't pass emissions, and is $2500 +/-, w/o tuning, and only a few and the proud can tune it in properly right now.
VEC2, $1000+/-, many out there that can tune it quickly and inexpensive
Split Second, $??, tuning similiar to VEC2
Casey is offline   Reply With Quote
Old 05-09-2005, 09:09 PM   #4
GR8_ASP
Does anyone know if the Split Second can control spark, fuel injectors and fuel pump on timing simultaneously? The Paxton system comes with a Split Second pre-programmed for spark retard and fuel pump control.
Note also I think the VEC can advance spark where the Split Second can only retard the spark, and retards it across the board by 1.5 degree. If anyone knows how to defeat that please do tell.
GR8_ASP is online now   Reply With Quote
Old 05-09-2005, 09:18 PM   #5
opnwide
S. Texas VCA Member
opnwide's Avatar
split sec only tunes fuel and spark, by manipulating signal to fool computer. (like the vecI but much more flexible)
opnwide is offline   Reply With Quote
Old 05-10-2005, 12:49 AM   #6
dansauto
The split second only alters the Map sensor signal, There are two versions one that can retard timing (but it is not progressive) and one version that only alters the map sensor. They also have a TMC1 which is a progessive timing retard with remote dial. (does not advance-but progressivly retards timing under boost) Both versions have an output function to control up to 2 extra injectors. The VEC2 can also advance timing. New split second PSC1 is about $200, the TMC1 is about $350
dansauto is offline   Reply With Quote
Where to get Split Second Box? ptmstr SRT10 and SRT10 Coupe Discussions 2 10-30-2006 07:16 PM
Split Second or Vec 2 KingSnake97 RT/10 and GTS Discussions 6 10-23-2006 11:10 PM
VEC 2 vs. Split Second?????? VIPERMIKE SRT10 and SRT10 Coupe Discussions 11 11-06-2004 08:31 PM
Does anyone know how to tune a Split Second computer? SMCBUILDERSINC RT/10 and GTS Discussions 4 08-11-2003 07:38 AM
