Old 05-28-2005, 04:31 PM   #1
Cal Cobra
Default Anyone using Side Sill Vents?
Saw these at partsrack:
http://partsrack.blastmart.com/custo...153&page=1
Seems like a good idea, anyone tried them yet?
Cal
Cal Cobra is offline   Reply With Quote
Old 05-28-2005, 05:37 PM   #2
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
Default Re: Anyone using Side Sill Vents?
Is that $75 for a set of two or four? or just for one individual piece?
Old 05-28-2005, 07:44 PM   #3
ViperRay
Funny you should bring them up... I just put them on today.
They are $69 from Parts Rack. They are bare aluminum but I painted mine red like the car.
They only go at the front of the sill so they come as a pair.
The reason I got them is because my exhaust hanger up front as it enters the sill pulled off the exhaust (at Mid-America) and made a hole which then burnt the paint off my sill up front and cooked the black reinforced cardboard (or whatever the material is) at the front of the sill.
My sills really otherwise run cool with the high flow cats.
But, they look good (when painted) and I suspect they probably decrease the sill temp if that's a problem for you.
ViperRay is offline   Reply With Quote
Old 05-28-2005, 08:25 PM   #4
charlesj
wow, that's a really good idea. too bad d/c didn't think about that when building the car. 10,000 toasted yellow side sills later. tell me gen3's fixed this problem. i haven't examined them closely, (whispering - i think they're ugly.) <- aaaahhhh plz don't stone me for that one, just my opinion & i do own a viper remember.
charlesj is offline   Reply With Quote
Old 05-28-2005, 09:50 PM   #5
ruckdr
WA VCA Member
ruckdr's Avatar
Cal,
Send me your email address, I will send you a couple pictures and something that might be of interest to you relative to the side sill vents.
Later, my email below.
ruckdr is offline   Reply With Quote
Old 05-29-2005, 12:14 AM   #6
radta7
Illinois VCA Member
radta7's Avatar
Don,
Send em to me as well. drawer@sbcglobal.net
I have Bellengers, hiflo cats and corsa and the front and first 9 inches gets hot still. Better than before but...
Thanks in advance,
radta7 is offline   Reply With Quote
Old 05-29-2005, 12:55 AM   #7
Randy
Randy's Avatar
Most people I've see do this kind of mod just use some heavy-gauge screen-type material, instead of paying $70 for stamped aluminum pieces. You get a lot better airflow, also.
Old 05-29-2005, 03:40 AM   #8
PHILIP
Does this actually help cool the sills???
PHILIP is offline   Reply With Quote
Old 05-29-2005, 04:08 AM   #9
Cal Cobra
Don,
Send em to me too please: b_severn@yahoo.com
So we don't really know if they work or not seems to be the consensus, although it seems logical they would. It would also seem reasonable to have them in the front and back of each side sill so the air can pass thru (IMO).
I've heard that some of the Viper shops are taking the stock cats, which if you look at them, are actually two cats welded together, and taking one off, so they are shorter. That may help with the heat as well.
Cal
Old 05-29-2005, 07:21 AM   #10
carl B
me too please
carl@cbridson.freeserve.co.uk
carl B is offline   Reply With Quote
Old 05-29-2005, 07:30 AM   #11
Jay Lopez
N Texas VCA Member
I had the same idea a few years ago and made something myself, but it was too fragile when hit by rocks. I pulled mine off and used the ones from Parks Rack and they worked much better. I left them the standard aluminum color and used a rivet gun to attach them. I did notice a cooler interior when on the track with the vents. I can't comment on the effects on the street since I don't drive on the street that often. I would recommend them to anyone.
Jay Lopez is offline   Reply With Quote
Old 05-29-2005, 08:06 AM   #12
Chuck 98 RT/10
Wouldn't it be beneficial to have them on the rear as well as the front, so the air coming in would have an exit?
Old 05-29-2005, 08:07 AM   #13
ViperRay
The thing about the pieces from Parts Rack is that the vents are shaped to keep debris from entering the sills.
They are shrouded. This probably decreases air flow through them but keeps junk out of the sills.
Old 05-29-2005, 08:09 AM   #14
ViperRay
That makes sense Chuck.
I've thought about simply drilling a series of holes in the rear pieces.
Not concerned about getting junk in them like the fronts.
Old 05-29-2005, 05:55 PM   #15
ruckdr
WA VCA Member
ruckdr's Avatar
In the rear ?? The rear is open to the inside, so not sure if holes, vents, or anything is necessary there, as the air will get out.
Later,
Side Sill Vents Daniel Cragin/DC Performance Inc New Products, Supplier Specials, and Group Buys 31 04-25-2008 06:31 AM
TVS Polished Side Vents? cayman RT/10 and GTS Discussions 5 07-25-2006 10:18 PM
Side Sill Insulation for GEN I Side exhaust ViperJames RT/10 and GTS Discussions 5 10-07-2005 04:39 PM
Repost: Anyone making vents to use fog holes as brake vents. PhoenixGTS RT/10 and GTS Discussions 8 06-30-2005 04:44 PM
Side Vents question BACKNBLACK General Viper Discussion 2 04-09-2003 10:48 AM
