I asked this sometime ago and only response I got was pictures of ninja stars in the fog light holes, then TooFast mentioned in passing that someone was making a vent to use ACR-style fog holes to get air to the brakes. Any new developments out there? Maybe the Vipar folks make something!
I've heard that the fog light position is not a high pressure area, so it would not introduce much air. But maybe with a little help it at least becomes a source of clean air, located where there is an unused 12V source.
NASCAR types use these fans for brakes. You could turn them on with the fog light switch. http://www.prosystembrakes.com/catalogpg022.htm |
Kansas City VCA Member
![]() Join Date: Jul 2000
Don't waste your time , as this is not an area that gets proper air flow. Woodhouse designed a brake ducting system years ago that got ton of air on the calipers/rotors, and then the indominatible Henry " I am Proud to be Anal," Cone came up with a kit that is a wonder to behold. It is downright pretty and well finished ,even though no one can see it. The Famous Paul Mumford built two flugle horns to protrude out the nose of his ACR to finally capture air, and he joked that his Horny Air Intake looked like and orchestra coming down the straights. Cone's adaptation of Woodhouse's idea is the most effective on the market, as it forces air onto the brake components at the highest pressure zone.
This is the number one item to keep your brake fluid from boiling, giving your brake pads double the life , as well as decreasing rotor wear. I ran through 3 sets of pads at Mid Ohio in 2000, and yet one year later with this system ( albiet the one we designed initially ) on a faster car, I made it through the entire weekend , a practice day for the next Viper Days event, and one morning track sesssion. The initial figure is a bit high to some, but you will get it all back in less than one year of events. |
Yep, Henry C. confirmed this in person Saturday when I asked him about those fog lights. They just look like natural vents through to the front brakes, but they are, alas, a low pressure area, and that dog just don't hunt.
Maybe I'll try the Porsche deflectors, and see if they help... |
Be careful with the carcass catchers. I have to do major avoidance maneuvers when road kill looms on the horizon. Those Porsche deflectors hang pretty low...
Banned
Bill, you have any pics/info on these brake ducts you would mind posting? Or should we contact you directly?
Just contact me, Mark Jorgensen, or Nancy Shanno directly.
Bill P 1-800-889-1893 |
I installed Henry's version of the ducts and concur with Bill P. and others that they're effective.
You do have to remove the front fascia and drill (3") holes in the radiator supports though. |
| Has anyone used these vents ? | FLX109 | RT/10 and GTS Discussions | 12 | 09-14-2006 03:26 PM |
| GTS-R central vents | Fiorano | RT/10 and GTS Discussions | 0 | 09-19-2005 05:34 PM |
| Hood Vents in a Gen I | GCHDEALER | RT/10 and GTS Discussions | 8 | 11-11-2003 06:40 PM |
| Vents in back of GTS????? | whip383 | RT/10 and GTS Discussions | 8 | 11-10-2003 06:24 AM |
| hood vents..how knows?! | Jason-Middle Tennessee | Archive Management | 5 | 01-02-2001 12:06 PM |
