Old 07-31-2005, 02:52 PM   #1
SHADOW
Default Help on cleaning engine compartment
Anything Viper specific in terms of spraying engine compartment with water/degreaser? How do u guys clean the area when its really grimy and dirty.
Thanks,
Dave.
SHADOW is offline   Reply With Quote
Old 07-31-2005, 04:03 PM   #2
Default Re: Help on cleaning engine compartment
same as i use on the outside of the car and i make sure to dry it well. I use towels and a leaf blower.
Old 07-31-2005, 04:25 PM   #3
Warfang
a full shoulder-packed gas-powered leaf blower? I can't see how that would help other than blow some loose dirt away.
Warfang is offline   Reply With Quote
Old 07-31-2005, 04:46 PM   #4
Supercharged Vipermad
Seasoned Enthusiast
Leaf blower to dry!!
Supercharged Vipermad is offline   Reply With Quote
Old 07-31-2005, 04:47 PM   #5
PhoenixGTS
He means to dry it after the washing is over.
I have always taken my cars to the high pressure do-it-yourself car wash to do the engine compartment. Problems with the Viper is the crazy heat underhood just does not allow for driving to the car wash and spraying cool water on it. A few months ago I figured out a solution. I took my car to a service facility to get the AC recharges after replacing all the o-rings in the leaking AC system. Right next to the shop is a do-it-yourself car wash. They got done with the car about 10:00 am but I did not go to pick it up until about 3:30. I drove the car for about 100 yards into the wash stall and and killed it immediately. Finally! I had the car at the car wash and it was not hot. I don't know what chemical is in those car washes when you switch it to engine degreaser, but it works awesome. I did $1 on degrease, $1 on soap, then $1 on rinse. The top of the block below the intake manifold was a mess and the high pressure stream cleaned it right up. I just blew the injector plugs dry, toweled everything else and drove off with no problems. Now if I can just figure out how to get the bottom side.
Old 07-31-2005, 04:56 PM   #6
Warfang, just for drying the engine and every nook and cranny on it.
Old 07-31-2005, 06:35 PM   #7
acrdakota
Banned
The foaming tire/wheel cleaner works very well to get a lot of the small crap off, plus it leaves all the wires/hoses nice and shiny.
acrdakota is offline   Reply With Quote
Old 07-31-2005, 07:11 PM   #8
Leslie
Leslie's Avatar
anything that needs to be covered when you hose the engine down?
on my vette I always put a plastic bag on the alternator, anything on the viper to watch out for getting tooo wet?
i like to use simple green works great
wanna do the GTS this wk
Leslie is offline   Reply With Quote
Old 08-01-2005, 03:22 AM   #9
i dont cover anything. just dont flood it. I use a gentle spray setting on my hose nozzle.
red fluid in engine compartment Muzz B Yellow SRT10 and SRT10 Coupe Discussions 6 08-11-2005 03:20 PM
Best way to clean the engine compartment? Abq Bill RT/10 and GTS Discussions 13 04-17-2005 12:21 AM
Canīt find fuse box in engine compartment: please help ! whitesnake RT/10 and GTS Discussions 5 06-17-2004 11:04 PM
engine compartment fires? onerareviper RT/10 and GTS Discussions 6 03-16-2002 07:45 AM
Engine Compartment Black Paint Code? JimDavis MT 97GTS 650R Performance Modifications 2 11-16-2001 02:58 PM
