Old 08-11-2005, 04:33 PM   #1
Dimitrios
Dimitrios's Avatar
Default Loads Of Motor Oil On Left Side Of My AirBox????
took my airbox off today to clean the air filters and first off the left side was soaked with motor oil and right side winshield washer fluid. figures why there is so much oil on my garage floor. I checked the oil level and it was short a quart and i just got the engine oil changed a month ago and drove it for about 800 miles. Secondly on the left side/driver side on the air box there was the most oil and goo right by where that tube from the valve covers goes into it. last and not least after taking the air box out i started the car for a sec and out of the tube that comes out from the valve covers and into the left side of the air box there was lots of smoke that stunk like crazy. is this normal for all that smoke to come out of that tube?
Dimitrios is offline   Reply With Quote
Old 08-11-2005, 05:11 PM   #2
Vic
Vic's Avatar
Default Re: Loads Of Motor Oil On Left Side Of My AirBox????
The oil from the valve covers sloshes forward under hard braking, and gets ingested into the airbox from the breather hoses. Even if you don't brake hard, there is always an oily residue that accumulates from the heavy vapors.
Road racers take the breathers, and either relocate them to the top of the valve covers so the oil won't slosh out, or just route them to a catch can, and plug the airbox breather inlet.
As far as the smoke, sounds like just hot oil vapors.
Vic is offline   Reply With Quote
Old 08-11-2005, 06:55 PM   #3
KenH
KenH's Avatar
Besides braking, the SC when in boost will tend to increase blow-by. I installed a catch can in my return line to catch most of the oil before it made it into the air filter. Losing a quart in 800 miles seems like more than you should be losing to me though unless a lot of those miles were under boost.
I assume that you have your water/meth injection up near the air filter? If you position it back closer to the throttle body, that should reduce the chance of the filter getting wet.
Old 08-11-2005, 07:13 PM   #4
his 800 miles had to be under boost....lol did ya call the wizard yet?
<<--- has seen him drive
plumcrazy is online now   Reply With Quote
Old 08-11-2005, 09:09 PM   #5
dansauto
Yep, you are going to have to make a catch can. I made one that drains back into the oil pan
dansauto is offline   Reply With Quote
Old 08-11-2005, 09:11 PM   #6
GTSnake
GTSnake's Avatar
Get a catch can. You're getting the "super charger blow by".
That's exactly what I had and you have to either change your piston rings or get a catch can.
Old 08-11-2005, 09:53 PM   #7
Dimitrios
Dimitrios's Avatar
change my piston rings??? what do you mean?
Old 08-11-2005, 09:54 PM   #8
Supercharged Vipermad
Seasoned Enthusiast
D..there are several catch cans ou there, and several threads about just this. I'll dig up the threads tomorrow when I have more time.
Supercharged Vipermad is offline   Reply With Quote
Old 08-11-2005, 10:41 PM   #9
Dimitrios
Dimitrios's Avatar
thanks T
Old 08-11-2005, 11:29 PM   #10
KenH
KenH's Avatar
Here's what I did on mine. I used a small Jaz puke can and put it in-line with the vent line from the valve covers to the intake box. I mounted it loosely where you see it in the picture by the brake reservoir. With the hoses coming in and out of the can wire tied down, the can is pretty secure. The hose runs a little uphill from the valve cover connections to the puke can which helps to encourage the oil to stay in the engine as much as possible. A hose is permanently plugged into the bottom of the can and run down by the PCM grounding stud. I can put the hose in a can and open the petcock to dump the oil.
I blocked off the breather vent in the puke can as I wanted all the blow-by gases to recirculate back into the intake rather than venting into the engine compartment, while the puke can catches most of the oil. This prevents the engine compartment from getting that nasty smell that you got when you disconnected the vent line and also maintains the emissions setup should anyone ask. I put a fine SS mesh cloth in the can to help separate the oil from the air as it passes through, but I don't think it is necessary.
I need to dress up the hoses a bit, but this setup seems to work fine and I have no oil in the intake.
Old 08-12-2005, 03:33 AM   #11
nice setup ken
Old 08-12-2005, 07:37 AM   #12
Simms
Simms's Avatar
Definitely get a puke can setup. You don't want those oil vapors sucking back into you engine anyway, it can cause detonation.
Simms is online now   Reply With Quote
Old 08-12-2005, 12:28 PM   #13
RED 93RT
Nice looking catch can setup. Where did you get it?
RED 93RT is offline   Reply With Quote
Old 08-12-2005, 12:57 PM   #14
tim721
yeah, i dont think there is 1 'easy mile' on that car..lol
tim721 is online now   Reply With Quote
Old 08-13-2005, 02:32 PM   #15
Simms
Simms's Avatar
If you are refering to mine, M2-Macedo Motorsports.
Front Bumper low on Left Side GTS02 RT/10 and GTS Discussions 8 07-16-2006 09:56 AM
Sensor on left front engine side unconnected... Black 94 RT/10 and GTS Discussions 10 10-08-2004 04:52 PM
2000 GTS ground strap under left side cowl Prfgdwrnch RT/10 and GTS Discussions 5 10-30-2003 09:38 PM
Anybody have left side sill for 1996 and up available? Sean Roe RT/10 and GTS Discussions 6 07-28-2003 09:51 PM
Replacement of Driver Side Wiper Motor jerryk96GTS RT/10 and GTS Discussions 8 01-08-2003 04:31 PM
