Old 08-18-2005, 09:49 AM   #1
Cjpjjones
Default 94 Rear End Capacity ?
Do you just service the diff. until it starts to run out ? Like most rear ends. Thanks, Chris
Cjpjjones is offline   Reply With Quote
Old 08-18-2005, 10:53 AM   #2
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
Default Re: 94 Rear End Capacity ?
Pretty much yes, but don't over fill. And don't forget the friction modifier.
Chuck 98 RT/10 is online now   Reply With Quote
Old 08-18-2005, 11:57 AM   #3
Cjpjjones
1 qt. dosen't seem like much (+ 4 oz. of friction modifier).Is it possible to over fill it ? I mean if it runs out that's pretty much it.
Old 08-18-2005, 11:58 AM   #4
Steve-Indy
IN/KY VCA Member
The diff holds 44 oz... I usually "rinse" it out with the extra diff fluid that I know I'll have, being sure to remove all that I can with the suction setup, then fill the diff with the 4 oz. of the friction mofifier, then fill with diff fluid til it begins to overflow...then, using the suction setup, take out a "touch" of fluid to avoid overfill as Chuck mentions.
Oil capacity for rear axel/diff? Kai SRT10 SRT10 and SRT10 Coupe Discussions 6 11-15-2004 09:22 PM
Engine oil capacity Simms RT/10 and GTS Discussions 9 08-27-2004 09:00 PM
SRT Oil Capacity? MiamiJeff SRT10 and SRT10 Coupe Discussions 15 04-05-2004 07:23 PM
Crankcase capacity Don Hiltz RT/10 and GTS Discussions 5 09-02-2001 08:38 AM
2001 Oil Capacity mit Archive Management 7 02-04-2001 02:45 PM
