Old 08-31-2005, 08:14 PM   #1
Matthew Klinger
Default using a buffer
Hello all.
I am a loyal Zaino guy. Use nothing but Zaino. I recently bought a buffer, just a simple 1 speed 6" buffer. My questions are:
What product should I use when using the buffer? Can I just use the Z-2? How easy is it to screw up a paint job when using a buffer? Any hints, warnings, or advice is greatly appreciated.
I already practiced using an older sander/buffer type on my beater car and I love the results.
Thanks again
Matt.
Matthew Klinger is offline   Reply With Quote
Old 08-31-2005, 09:20 PM   #2
carguy07
carguy07's Avatar
Default Re: using a buffer
Not an expert here, but I think there would be little to gain by using a buffer to apply Z2. Z5 or Z-PC would be a different story,(Z5 is useless so just get the PC) there is some abrasive in it. The only buffer you should be working with is a random orbital, otherwise you will ruin your paint. Get a Porter Cable and be careful and you should be fine.
carguy07 is offline   Reply With Quote
Old 08-31-2005, 10:34 PM   #3
Matthew Klinger
Whats a porter cable? . I have Z-PC. My buffer is a orbital that has just one speed, will I be ok?
My thoughts are, a coat of Z-PC and then follow it up with a few coats of Z-2. I will probably practice on my beater car. If anyone else has any thoughts or ideas for me please let me know.
-Matt
Old 09-01-2005, 09:59 AM   #4
carguy07
carguy07's Avatar
Read up about them here http://www.autopia-carcare.com/inf-pc7424.html or search this site. What you are describing does not sound like the type of thing I would use on a Viper. It does not sound like a random orbital.
Old 09-01-2005, 10:58 AM   #5
ruckdr
WA VCA Member
ruckdr's Avatar
Use what the pros use:
http://www.rightlook.com/
I have seen these products in professional detail shops.
I have been using these products, and was asked this past weekend what I use on the car; this was at a car show where "show and shine" is the ultimate.
Later,
ruckdr is offline   Reply With Quote
Old 09-01-2005, 01:21 PM   #6
Gerald Levin
Here is one of the most popular buffers that is well liked here:
http://www.coastaltool.com/cgi-bin/S...082908585#cart
Literally impossible to screw things up with this buffer. I wouldn't use anything else.
Gerald Levin is offline   Reply With Quote
Old 09-02-2005, 03:20 PM   #7
Matthew Klinger
Thaks to all for your help. What is the difference btwn that buffer and this one:
http://www.homedepot.com/prel80/HDUS...mp;cm_ite=prod
Other than the fact that the first one youcan change speeds (2,500-6,000) while the second one is constant at 4,000.
Also, the main focus to my original question was to learn what to do with the buffer. I mean the steps or the products.
Thanks again
Matt
Old 09-02-2005, 03:36 PM   #8
Jeff Torrey
Jeff Torrey's Avatar
In my opinion a buffer is to aggressive for what you want to do. I suggest the Porter Cable Random Orbital Sander from Autotopia (above).
The problem I have had with the buffer is it leaves "Holograms". To much heat...it liqufies the wax and you can't get an even coat. Not to mention you could burn through the clear coat on your car. It's clumsy, throws polish, compound and wax everywhere.
Jeff Torrey is offline   Reply With Quote
Old 09-02-2005, 06:50 PM   #9
Leslie
Leslie's Avatar
I have the Griot's garage orbital, LOVE IT. Next to impossible to damage the car
It has 3 levels of polish for getting out swirls to scratches, depending on how deep you want to go into the clearcoat
Leslie is offline   Reply With Quote
Best Buffer? Purdue_Boiler_Viper Viper Detailing Tips & Tricks 27 07-23-2007 10:11 AM
Swirl Marks & Orbital Buffer Questions DodgeViper01 RT/10 and GTS Discussions 18 11-06-2005 09:53 PM
Porter Cable Orbital buffer vette2viper RT/10 and GTS Discussions 11 08-11-2004 10:51 PM
orbital buffer Blue Pilot Sneaky Pete's Place 6 08-22-2003 11:01 PM
Does the back window work as a wind buffer? 2001 Sapphire Blue RT/10 and GTS Discussions 17 06-30-2003 04:10 PM
