Old 09-12-2005, 08:36 PM   #1
ViperRichRT10
Default Boost Guage Install???
Who can tell me how to hook up an auto meter boost guage? I have a 2001 w/Roe SC and VEC2. I'm sure there must be an easy way to tap into the VEC2 since it already knows this information.
Thanks, Rich
ViperRichRT10 is offline   Reply With Quote
Old 09-12-2005, 09:29 PM   #2
orlandov10
Default Re: Boost Guage Install???
mechanical gauge?
just T into the vaccum line at the vec II and run it into your car.
pull power from the fuse box in the car
make sure you only use a short rubber hose then run the rest with the hard hose that comes with the gauge
orlandov10 is offline   Reply With Quote
Old 09-12-2005, 09:46 PM   #3
Joseph Dell
Georgia VCA Member
Rich - my wife is out of town tomorrow. bring it by and we can be done in 10 min or less!
JD
Old 09-12-2005, 11:35 PM   #4
1TONY1
1TONY1's Avatar
First pull the s/c then the intake...drill hole, then tap 1/8 npt hole in rear vertical surface of intake.....thread in 1/8 npt to 1/8 tube fitting....... reinstall intake...reinstall s/c...... run tubing to boost gauge. Nothing to it....take JD about 15 minutes
Old 09-13-2005, 06:01 AM   #5
Joseph Dell
Georgia VCA Member
can't you just tap into the vacume line that the vecII is using?
if not, then rich - stay home...
JD
Old 09-13-2005, 09:01 AM   #6
ViperRichRT10
I hope Tony is just trying to be funny! I can't come by today to do it JD. If it is a ten minute job, tell me and I can "Get-R-Done"!
Thanks,
Rich
Old 09-13-2005, 09:32 AM   #7
orlandov10
Its simple, I would say one hour to mount the pod and all. Just use a vaccum T and cut into the VECI vaccum hose, then run a 3" piece of vaccum hose onto the T, hook up the little step down adapter and push the hard line into that adapter, run the hardline under the ECU area, there is a spot under there to run easily into the car, you'll have to reach around the back side and you will have to cut a slice into the rubber grommet. run the hose through there then open the door and pull it through, simply pull power from the fuse box inside the car. Make sue you pull power from the side of the fuse that dies if the fuse pops
Old 09-13-2005, 09:51 AM   #8
1TONY1
1TONY1's Avatar
JD
Only if you want the easy way out !!!
Old 09-13-2005, 12:48 PM   #9
orlandov10
JD
hahahaha!!!! LMAO
Old 09-13-2005, 01:18 PM   #10
FLX109
FLX109's Avatar
OK Tony,
I have that done but do I have to get new gaskets? where can I purchase them? This has taken me about 5 hrs so far , I thought you said it would only take 15 minutes tony? I don't understand, I got this all ...ked up now. HELP
I might have to call Sean Roe.
FLX109
FLX109 is offline   Reply With Quote
Old 09-13-2005, 06:56 PM   #11
1TONY1
1TONY1's Avatar
OK Tony,
FLX109
It will only take JD about 15 minutes....you and I...we are talking 7 hours Use new gaskets !! Really, that is the way mine is done.
Old 09-13-2005, 07:38 PM   #12
Joseph Dell
Georgia VCA Member
It'll take me 15 minutes to figure out that i can cut some serious corners to make it work easier and faster.
JD
Boost guage problem Pressured RT/10 and GTS Discussions 6 11-12-2006 12:31 PM
boost guage lighting FLX109 RT/10 and GTS Discussions 1 02-27-2006 04:56 AM
Boost Guage For Roe SC Dimitrios RT/10 and GTS Discussions 7 09-06-2005 05:22 PM
Gen 1 Boost Guage Mount? RED 93RT RT/10 and GTS Discussions 0 08-18-2004 08:11 PM
who makes a playback boost guage twinvipers RT/10 and GTS Discussions 12 06-09-2004 09:15 AM
