Old 09-17-2005, 11:57 AM   #1
SilverViperGTS
VCA MemberWHERE importuserid=Quebec
Default Major Coolant Leak (1997 GTS)
Here is the story:
My engine had compression problem in cylinder no.8. They removed the head and they had to replace two valves, two pushrods and they had the head resurfaced. They also replace the head gasket. I got my car yesterday and everything was fine until I got home (20 km away from the garage). I then pushed the car to 5000rpm (the engine was running fine and the temperature was perfect) and I saw white smoke coming from under the hood. I stopped the engine (the temperature was also ok at this time) and I saw a huge trail of prestone behind my car (at least 5 to 6 liters). I checked under my car and I saw a big pool of prestone (at least 2 liters). Bottom line, my car lost almost all its prestone in less than a minute!! It looks like the leak comes from the radiator!! Do you have any idea of what is going on? Keep in mind my car NEVER overheated.
Edit: When I started the engine the first time, I heard a little whistling noise... like a tiny supercharger noise.
SilverViperGTS is offline   Reply With Quote
Old 09-17-2005, 12:37 PM   #2
Joseph Dell
Georgia VCA Member
Default Re: Major Coolant Leak (1997 GTS)
Sounds like a hose is loose. Easy way to check is to go to AutoZone or PepBoys and do the "loan-a-tool" for the radiator pressure checker. then pressurize the system and find the leak.
sounds incredibly minor. don't panic yet!
JD
Old 09-17-2005, 08:55 PM   #3
ArlyDude
I guess your garage doesn't test drive cars when they fix um.
ArlyDude is offline   Reply With Quote
Old 09-17-2005, 11:09 PM   #4
BLUESNAKE367
My stock radiator hoses gave out about 2 months ago. while I was driving along at 35mph, decided then, no more stock hoses, called Roe Racing and got the silicone hoses, these puppies wont blow out.....
Hope all turns out ok for you...
BLUESNAKE367 is offline   Reply With Quote
Old 09-18-2005, 07:18 AM   #5
Blue Streak
Hey Bluesnake367, how can you tell what number yout GTS and indy ram is? Send me a PM.
Blue Streak is offline   Reply With Quote
Coolant Leak Question ViperTony RT/10 and GTS Discussions 3 07-23-2006 07:01 PM
Did 1997 GTS' have 2 different cams during the year? Buckeye Viper RT/10 and GTS Discussions 7 07-21-2004 04:53 PM
Need Help with Coolant Leak jgrakla RT/10 and GTS Discussions 7 09-14-2002 01:09 PM
Coolant leak ??? Help, I'm freakin' out. Daffy RT/10 and GTS Discussions 9 04-25-2002 07:00 PM
Seem to have small coolant leak - will a tristan rizzi RT/10 and GTS Discussions 1 01-22-2002 07:40 PM
