Old 10-03-2005, 08:21 AM   #1
PAULIE G
Default Greenstuff Brake Pads
Does anyone have any experience with these pads? I'm trying to eliminate some of the brake dust and the occasional squeak. Do they do that and do they stop the car as well?
PAULIE G is offline   Reply With Quote
Old 10-03-2005, 08:51 AM   #2
Early93Viper
Kansas City VCA Member
Early93Viper's Avatar
Default Re: Greenstuff Brake Pads
There OK............they don't have the performance of some other brake pads. But they are better with dust. I would say they have around the same stopping power as OEM with less dust and less squeak. But that's just my opinion.
Early93Viper is offline   Reply With Quote
Old 10-03-2005, 09:29 AM   #3
Don_
I'm using the greenpads and less dust and I haven't squeaked yet!
Don_ is offline   Reply With Quote
Old 10-03-2005, 09:46 AM   #4
BigCarrot
Much less dust and noise, but you do give up some stopping power.
Old 10-03-2005, 04:01 PM   #5
snampro
snampro's Avatar
I assume you guys are talking about the EBC Greens? where are you getting them, I need some for the rears...
Old 10-03-2005, 04:13 PM   #6
Don Hiltz
AL/TN VCA Member
Don Hiltz's Avatar
Ben,
Try PartsRack
Don
Don Hiltz is offline   Reply With Quote
Old 10-03-2005, 04:16 PM   #7
BigCarrot
www.greatbrakes.com
Old 10-03-2005, 04:23 PM   #8
Vipera Russelli
Just make sure you condition your rotors when you switch over to EBC Greens or they won't work very well. And don't even dream of using them at the track as they are not rated for track temperatures caused by repeated hard braking.
Vipera Russelli is offline   Reply With Quote
Old 10-03-2005, 05:12 PM   #9
snampro
snampro's Avatar
Don, you need to change that avatar, that's my car...
thanks for the tips guys...
Old 10-03-2005, 05:21 PM   #10
vipeuup
about brake pads. Has anyone here, checked out the good prices/selections, at the Tire rack??
http://www.tirerack.com/brakes/resul...&brand=all
vipeuup is offline   Reply With Quote
Old 10-03-2005, 06:40 PM   #11
Purdue_Boiler_Viper
Put EBC greens on mine about a month ago. Painted the backs with high temp black paint so green would not show. Make sure you follow the DC manual exactly, especially on the rear brakes, or you will damage the caliper. I used stout needle nose for the special tool called for.
Be sure to clean all of the corrosion off the rotors. 3M kit reportedly does great job, or you can use scotch green pads. Just make sure you get them completely clean.
They will come with a wire attached. Simply clip off.
Almost silent now vs. horrible squeaking with stock pads. Stopping power is as good or better for street driving.
Old 10-03-2005, 08:46 PM   #12
Brian GTS
I have them on both of my Vipers. It seems as if they changed the composition of the pads compared to a few years ago. The ones I bought a few years ago have next to NO brake dust. Today's EBCs are much worse as far as brake dust is concerned. I'm sure they're better than stock pads, but definitely not as good as they were several years ago. I can drive my 01 100 miles and have minimal dust. If I take the 97 out for 25 miles, I can see the front rim getting dark from the dust. What's the deal? A buddy of mine has the same results with his new EBCs. Hmmmmm...
Brian GTS is offline   Reply With Quote
Old 10-04-2005, 09:13 AM   #13
Purdue_Boiler_Viper
Agree with Brian. Brake dust is not much better , if at all vs. stock. But quieter.
Why use Grabbier Brake Pads in Front? Brake Pad Life? Vipera Russelli SRT10 and SRT10 Coupe Discussions 5 04-08-2006 03:54 PM
Brake Pads: Which replacement pads most like OEM? Kai SRT10 SRT10 and SRT10 Coupe Discussions 5 02-24-2005 12:49 PM
EBC Greenstuff or Hawk HPS Brake pads? CTViper SRT10 and SRT10 Coupe Discussions 10 12-23-2004 11:02 AM
EBC Greenstuff Pads dragging rotors? 1MEANSNAKE RT/10 and GTS Discussions 6 04-17-2004 03:02 PM
Price for Greenstuff EBC disc brake pads? Daffy Archive Management 2 05-03-2001 04:34 PM
