Old 10-03-2005, 09:34 AM   #1
Eric H
Default s-afc vs VEC I or VEC II which to get?
Obviously i kow the VEC is the "macdaddy" but if i just need basic fuel tuning anyone have any downside to going with the s-afcII? or is the VECI better for any reason?
I did a search and only found a few people using the s-afcII
Eric H is offline   Reply With Quote
Old 10-03-2005, 09:46 AM   #2
davem
Default Re: s-afc vs VEC I or VEC II which to get?
Eric,
The VEC II by far is the best as you have direct control over timing and fuel -If you are forced induction than it's a must. Then the AFC is next best, gives you MAP sensor based fuel control vs RPM over 2 throttle ranges and has cool displays (I posted instructions on how to install this a few years ago). Don't bother with the VEC 1.
good luck,
Dave.
davem is offline   Reply With Quote
Old 10-03-2005, 09:53 AM   #3
Eric H
Thanks Dave, I actually saw your post before i posted mine and copied the wiring instructions to my desktop, i found an s-afcII new on ebay for $240 so i'll probably get that for now.
