I ask this because I'm somewhat baffled. For those who do not know a "TRUE" BB is based on it's bore and configuration. The V10 has somehwat small pistons (Take a look at a 426 Hemi of a Big Block Chevy if you doubt me) compared to traditional big blocks. Did Dodge do it as a "Marketing Ploy" or am I missing something? I read the V10 is based off the 360ci small block so this would confirm that is's a LARGE small block rather than a True BB.
No flame intended it's an impressive motor none the less just curious on the subject. |
Semantics
I thought that big block/small block was because of the size of the block, not the pistons. The C6 ZO6 is a small block though it is a 427.
I agree with Makara.
The pistons (bores) tended to be larger in the BB's because the block was large enough to make the bores bigger without encroaching on one another. All the big displacement engines in those days were in Big Blocks. Today's technology has allowed larger and larger bores in traditionally small blocks. The new ZO6's larger bores are such that the steel liners are actually touching one another... no more block left between them! That's what happens when you put large bores in "small" blocks. I hope they're strong! |
PS... I'm not aware that there was ever a specific size that differentiated a small and large block.
I believe many of the large blocks were derived from trucks though. |
#6 | |
#7 | ||
#8 | ||
#9 | |
I have always wondered the same thing????
the pistons of a dodge viper are huge. they are not small whatsoever. the bore of the 488 is 4 inches, the bore of the 505 is 4.03 inches. compare to a murcielago at 3.43 inches and an enzo at 3.60 inches, the viper has serious pistons. from my view, jackhammers.
now the 426 hemi -- also a chrysler engine -- does have a larger bore than the viper's 488 and 505. the 426 hemi bore is 4.25 inches. but that certainly does not make a viper piston small. one is giagantic, the other is giagantic plus a quarter inch. however, the viper's stroke is longer than the hemi's, so when it comes to moving air through the engine, the viper is superior. the terms big block and small block have nothing to do with pistons nor displacement. it was just the size of the big old block that was needed to keep the engine together back in the day. nowadays our engines are fully cast aluminum by the italians, so we do not need a big heavy block. the terms big block and small block are basically of the past. if the viper is classified as a big block, than that is not good. the only thing that matters is displacement. aluminum blocks are strong and far lighter. more power to less weight. the new z06 has a bore of 4.13 inches and stroke of 4 inches. so ultimately it has larger holes than ours. but since we have two more, we win in terms of displacement. |
take 2 cylinders away from the 488 CI V-10 engine that resides in my viper and you have a 390 CI V-8. chevy made big blocks back in the 60's that were 396 CI.
the srt-10 has even more displacement than a gen-2 viper so the vipers V-10 engine is a modern day big block if you will. now chevy's new C-6 Z06 is technically a small block and those 427 cubes are large. chevy's 427 is the biggest factory small block engine ever offered in a production car. |
the 330 CI engine that resides in my ford lightning is one way stroked factory engine. the bore is a mere 3.55 inches while the stroke is the same as a 426 hemi at 4.15 inches. throw a blower on top of that and you have the ford lightning. drive one and you will get a whole new perspective on torque relative to the small displacement. the lightning engine hits you in the back hard. so hard in fact that when i launched at the drag strip on slicks a few years ago i busted the lumbar support in my seat.
i aint no fatty either ( i weigh 200 lbs) 500 rwtq + 4800 lbs race weight = 1.70 sixty foot time. |
the viper engine is not a big block or small block. those terms were for old cast-iron engines, like the 427, 454, and 426 hemi. the viper has a cast-alluminum alloy block. just because it displaces 488 or 505 cubic inches of air after all ten cylinders complete one full cycle, has nothing to do with the size of the block.
i can buy a block of iron the size of an aircraft carrier. than drill one hole in it exactly the size of a q-tip. the block is big, but the engine only displaces a squirrel's fart of air. displacement is not a measurement of block size. displacement is a measurement of the amount of air an engine moves after all cylinders complete one cycle. a viper's engine has a displacement of either 488 or 505 cubic inches. this does not mean that the block is 488 cubic inches. this means that after all ten cylinders complete one cycle, 488 or 505 cubic inches of air is moved. nowadays who cares how big the block is. the smaller the better. because smaller is lighter. cast aluminum blocks with cast iron liners allow for larger cylinder holes, spaced closer together. more displacement, less block. |
#15 | |
Banned
| Is there a difference in a Viper racing block vs. Stock Viper block? | ab | RT/10 and GTS Discussions | 3 | 04-02-2005 02:28 AM |
| need a 2000 short block or bare block | MIKE-HKS | RT/10 and GTS Discussions | 0 | 01-21-2005 04:58 PM |
| Anybody have a bare block or complete engine or short block.... | 1TONY1 | RT/10 and GTS Discussions | 5 | 07-16-2004 10:30 PM |
| What is considered more valuable? | Mike_W | General Viper Discussion | 11 | 03-21-2004 10:29 AM |
| If you EVER considered a Porsche TT | bad viper | Sneaky Pete's Place | 7 | 10-05-2002 11:01 AM |
