Old 10-10-2005, 08:52 PM   #1
SilverSnake
Default Pilot Sport Cups VS V700 Kumhos
I have used the search feature and came up with mixed reviews. I am using them mostly on the street and some mixed track time ( drag & roadracing ). So my question is witch is better for my application ? The biggest problem is the kumhos are on backorder at tire rack till the end of the month if I'm lucky. I have found the Pilots cups instock for around 1300 dollors for the set. The kumhos can be had but at the same cost as the pilot sport cups. So what should I do.
Robert
SilverSnake is offline   Reply With Quote
Old 10-10-2005, 10:01 PM   #2
'97 Viperidae GTS
Default Re: Pilot Sport Cups VS V700 Kumhos
You can get a set of the V710s for about $950 shipped/heat cycled. This is basically the shaved version of the 700s from the factory. They have excellent grip at the track (ie road course), along with very good durability. They are also fine for the street, as long as you don't drive in the rain. They are MUCH better than Michelin Pilots for road course racing. I have no idea how they perform at the strip...
'97 Viperidae GTS is offline   Reply With Quote
Old 10-10-2005, 10:11 PM   #3
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
The only thing Michelin has that sticks as well as Kumhos is mounted on a F1 car.
Chuck 98 RT/10 is online now   Reply With Quote
Old 10-10-2005, 10:54 PM   #4
SNKEBIT
SNKEBIT's Avatar
LMAO!!!!!!!!!
p.s. i didn't shave or heat cycle mine. last a little longer that way. tires are spendy enough, why shorten the life of them.
SNKEBIT is offline   Reply With Quote
Old 10-10-2005, 11:24 PM   #5
GTS Bruce
GTS Bruce's Avatar
Shaved tire.less tread squirm and heat build up.Heat cycle to toughen/harden the compound,reduce wear. GTS Bruce
Old 10-11-2005, 09:27 AM   #6
SNKEBIT
SNKEBIT's Avatar
ty
for education
Old 10-11-2005, 09:36 AM   #7
SylvanSRT
SylvanSRT's Avatar
shaving is also for optimum performance right out of the box, like in a racing situation. it also means less tire for you to wear down. if you are using them in driving schools or track days only i would not shave them and wear them down my self you will get much more life out of them. additionally i would do the heat cycling myself either at home or at the track, i dont see the reason to pay someone else to do this. my first set of khumo victoracers for my miata i bought heat cycled and shaved, second set(still using) did heat cycle myself and started using w/ full tread and have much more life than my shaved set. it just takes a little time/wear to get into the "sweet spot" of the optimum handling. Unless you are using the tires in a competitive situation(racing) you probably dont need a tire to be that race ready out of the box. IMHO
Old 10-11-2005, 11:47 AM   #8
AJT
Houston VCA Member
AJT's Avatar
Love my Pilot sport cups. Where did you find them for 1300 a set?
AJT is offline   Reply With Quote
Old 10-11-2005, 11:53 AM   #9
AJT
Houston VCA Member
AJT's Avatar
Kumhos seem to have a sandblasting problem.
http://vca2.viperclub.org/forums/sho...o=&fpart=1
Old 10-11-2005, 01:19 PM   #10
2002_Viper_GTS_ACR
NorCal VCA Member
2002_Viper_GTS_ACR's Avatar
Michelin Pilot sport Cups sucked on the street for me. They had wheel hop like mad, and skipped across the pavement in turns where I was trying to get the ass to come out. They are probably GREAT on the track, but worthless on the street, and I had them when I was NA and Booooooosted. So I know in both situations they were not worth the money, and they lasted all but 6k miles.
Kuhmos which I have never owned, seems to usually get good responses from people on here, so I think thats what I am going to try next. I have tried a lot of wheel/tire combos on my viper, with 56k miles on it, I'd say I have some good working knowledge.
Jon
Old 10-11-2005, 01:39 PM   #11
AJT
Houston VCA Member
AJT's Avatar
Jon
Strange, I have had great results. Never had wheel hop, takes corners like its on rails, great traction (857 rwhp).
They are expensive & probably would last only 6-9K ,miles.
I have 345s on the rear.
Andy
WHERE did you find them for 1300.00????????????????
Andy
Old 10-11-2005, 04:34 PM   #12
ACR steve
anybody else had issues with Pilot Sport Cups on the road?
ACR steve is offline   Reply With Quote
Old 10-11-2005, 09:24 PM   #13
SilverSnake
Thanks for the responses. I still haven't made my mind up yet but am leaning toward the kumhos. I will give up the pilot cup vendor as soon as i buy a set of tires.
Robert
Old 10-12-2005, 12:00 AM   #14
2002_Viper_GTS_ACR
NorCal VCA Member
Ps those that need some, there are some cups on ebay right now !! look under viper tires !!
Jon
Old 10-12-2005, 12:49 AM   #15
gallaugher
i just had my pilots replaced with v700s. i bought them from tirerack. my tuner told me not to have them shaved, because i only drive my viper on the street. but of course i had tirerack shave them anyways.
big foolish mistake.
for the track, shaved v700s will stick like a kart. but for the street, they become a little dangerous. there is basically no tread depth to channel water. i never plan to drive it in the rain, but sometimes it just happens.
from purely a street advantage, i suggest not to shave them. but if you track v700s without shaving, i heard they break apart and wear badly uneven. but i do not know from real experience.
and when they say shave, the really mean it. i was shocked how little tread remains. it might just be 2mm, but it looks a whole lot more.
gallaugher is offline   Reply With Quote
HRE + Pilot Sport Cups Xhlr8n SRT10 and SRT10 Coupe Discussions 1 05-20-2007 01:26 AM
HRE and Pilot Sport Cups Xhlr8n RT/10 and GTS Discussions 0 05-19-2007 01:14 PM
HRE and Pilot Sport Cups Xhlr8n RT/10 and GTS Discussions 0 05-19-2007 01:13 PM
Pilot Sport Cups Camfab RT/10 and GTS Discussions 14 08-05-2006 11:56 AM
pilot sport cups GOT VENM SRT10 and SRT10 Coupe Discussions 6 02-21-2005 01:17 AM
