Last week I started to hunt around for a new rear window rubber seal for my 2001 RT.
I soon discovered that you cannot get the seal alone, and basically need to buy a whole new window (approx $500) Well me being half Jewish, half Scottish, and half Irish, I set about trying to find another solution. After visiting a few trim places and manufacturers I came across a rubber which works pretty well. Installed this morning and pictures are attached. Looks really good and fits well. For those that are interested; To remove what is left of the damaged seal I used a Stanley knife. Heat did not seem to help. You just have to cut of the old one and get it cleaned up as best you can. This took me about 1 hour. I installed the new seal in about 10 minutes using a rubber mallet where needed, mainly on the corners. Start and finish is top dead centre. The seal is a tubular bulb design with two lips. I purchased the seal from www.McMaster.com page 3214 #9 (part # 12335 A421) 10ft length. Total cost was $20.56 delivered to my door. Will also work for Gen 1 windows |
#2 | |
Can you post a picture of the window out of the car?
I would like to see how the corners look. |
#4 | ||
With a few photos, this would be a good post to keep in the DIY section. Thanks for the info Kwik!
THANKS!
Exactly what I need! |
Great info, more pics please!
Awesome info! If anyone else is planning to do this, could one of you please make a tracing/template of the actual glass, so that a new one can be cut?
yes more info...
obaa: PM sent |
Is it a good fit? Or does it make the rear window alot tighter where it barely wants to pop out?
Here are some more pics. They are a bit hard to see as the rear window is tinted.
The window fits just as good as with the stock seal. Steam cleaned the car today and it did not leak. |
------------------------------------------------------------------------------- Well me being half Jewish, half Scottish, and half Irish, I set about trying to find another solution. ------------------------------------------------------------------------------- ----------------------------------------------------------- Larry, I see you are in Real Estate. Is your sense of humour in Escrow? |
Ontario VCA Member
trying to locate the part on the website can't find it do you have exact link
Ontario VCA Member
Yo KWIK96
Do you have a exact link to the section on that window seal part, tried to find it can't Thanks |
#15 | |
Thanks for the extra pics. If it seals as good as it looks, you may have just saved the RT/10 owners a bunch of head ache and money.
The only thing I would try is to put a little heat on the inside corners to get rid of where is sticks out, otherwise it looks terrific. |
Kwik found a great site. Put in "rubber edge seal or moulding" and other options come up too.
Man, this is great. I have been wanting to fix my window for years but thought it would be too much of a pain. Thanks for the tip.
That looks like a great option, however as an alternative to you guys; I have found a "seal" that is the same "shape" and "dimension" as the one that came from the factory (my car is a 95). The groove that the window sits into is the same depth as the original and the outside part of the seal (the part that touches the car and makes the "seal) is exactly the same. I bought 75 feet of it (smallest amount I could buy) to re-do my window. Like I said just an option if someone wants to go back with something that looks closer to the original. I can send you a pic of the seal itself so you can see the shape if anyone is interested.
#20 | |
#21 |
I just got the seal today. Looks great thanks for the heads up and am looking forward to finally fixing my seal!
#22 |
Very cool. Can you post a pic for us? Thanks.
[/quote] Ok need some help as I am new at this. Can someone please tell me how to include a pic in my post. I am sorry for my ignorance . . . |
#23 | |
#24 |
Have extra! Lots, . . . tell me how to post a stinkin' pic!
#25 |
Ag: sent you a PM
#26 |
Here's the pic Ag sent me
#27 |
thanks for the help Chad!!
#28 |
No problem John. I just sent you an email explaining how to upload pics. Hope it makes sense!
#29 |
Okay, so now a pic of the actual window with that seal on it?
#30 |
Ag's'95, where did you order the strip that you used from? Also do you have a part number? Some pics of your completed project would be great. Also, what was the cost?
Thanks. |
| Need help replacing the rear window seal on an RT/10 | V10SpeedLuvr | RT/10 and GTS Discussions | 3 | 11-28-2005 08:26 AM |
| '95 RT/10 rear window seal | revived_gearhead | RT/10 and GTS Discussions | 1 | 09-06-2005 02:43 PM |
| RT/10 Rear Window Seal - Silicone, Conditioner, etc? | Jon-Mike | RT/10 and GTS Discussions | 3 | 05-16-2005 10:52 AM |
| RT10 Rear Window Seal | THOR | RT/10 and GTS Discussions | 26 | 11-22-2003 08:21 AM |
| 99 rt/10 weather seal rear window | frankie s | RT/10 and GTS Discussions | 3 | 11-14-2003 10:56 AM |
