Old 12-15-2005, 10:07 PM   #1
Knight Viper
Virginia/Maryland VCA Member
Knight Viper's Avatar
Default Ever had this happen
I have an o2 yellow RT/10 (awesome) a couple of weeks ago the battery light came on then went off again. Today I stopped at a gas station and when I went to leave the car went dead like it grounded out. I was able to get a jump from a big roll-back a normal truck wouldn't turn the motor more than once. As I was heading down the road the car went dead again, the volt meter was reading @ 15v. I had the car towed home and removed the battery seemed fine put it back in and the car fired right up but when I had the battery out it wasn't strong enough to jump from the under hood post. Ever herd of something like that? Thanks for your time!
Knight Viper is offline   Reply With Quote
Old 12-15-2005, 10:12 PM   #2
got one
Central Texas VCA President
got one's Avatar
Default Re: Ever had this happen
not I...but would be interested as well to find out what caused it...electrical issues are always fun
Old 12-15-2005, 11:39 PM   #3
Vic
Vic's Avatar
Can you rephrase that?
Anyway you say it, sounds like its time for a new battery. Auto Zone can test it for you if you aren't certain.
Vic is offline   Reply With Quote
Old 12-16-2005, 07:27 AM   #4
Knight Viper
The battery checks out okay (and will start the car now).
What I was trying to say is that; the pick-up truck that was giving me a jump the first time only had enough power to turn the motor over once, then quit. The roll-back did the same until he added his "jump box" with the cables from his truck to get me going. then a couple of minuets later dead again.
Old 12-16-2005, 05:26 PM   #5
2000GTS
The battery post might be corroded. I had a similar problem in my Ram. I wire brushed the posts and the truck ran fine ever since.
2000GTS is offline   Reply With Quote
Old 12-16-2005, 07:42 PM   #6
DrumrBoy
IL VCA Member
DrumrBoy's Avatar
When the weather changes in Chitown and the air goes from 100% humidity to 0% in a day and then back again, I tend to get that white fluffy crap on the posts too. Not sure exactly what makes it happen but it can totally insulate the post from the pickup. If you saw ANY white stuff around the post, this could be your gremlin. Its so flaky that even wiggling the cable manually can turn a dead no-starter into just fine. Clean 'em up and you're ready to rock.
DrumrBoy is offline   Reply With Quote
Old 12-18-2005, 03:10 PM   #7
Knight Viper
The crazy part was that it died going down the road (45mph in gear)....The car will run with the battery disconnected.
Old 12-18-2005, 03:14 PM   #8
ab
ab's Avatar
Check your grounds. I had something simliar happen to me. It turned out it was a bad ground.
Old 12-18-2005, 07:42 PM   #9
Knight Viper
Thank you, I did, now I just don't know if I found it or not because the car was acting fine when I started the search...
Old 12-19-2005, 10:09 AM   #10
99 R/T 10
99 R/T 10's Avatar
Where did you find the bad ground? Pictures always helpful
Old 12-19-2005, 11:25 AM   #11
Knight Viper
I went over the battery leads positive and negative (on the starter & frame) and cleaned them added dielectric grease and reinstalled them but I didn’t find any obvious loose or corroded areas. The car is acting fine 'now' but I don't want to have to tow the car again, not easy when they sit this low.
Old 12-19-2005, 11:30 AM   #12
Knight Viper
How many ground areas is there on this car that would affect something like this? I did the one by the battery and under the hood where the jump post is located.
Old 12-19-2005, 12:26 PM   #13
2000GTS
Mine also looked fine. Just weren't shiny anymore. After I wirebrushed them where they were shiny and clean the worked fine.
Bill
Old 12-19-2005, 01:19 PM   #14
Randy
Randy's Avatar
Many years ago, I had a battery become disconnected *internally*. Press on it a certain way, and it would fire right up. Press on it another way, 0 volts. Had to drive 30 miles home from work with no battery that day - which was an interesting experience (don't think you could to that with today's electronics, etc).
Old 12-19-2005, 11:00 PM   #15
DodgeViper01
DodgeViper01's Avatar
Never heard of this one but good luck with the fix. I am still shocked on the location of the Battery in the GEN II's.
Did This Happen to Anyone Else ? Dimitrios RT/10 and GTS Discussions 12 08-24-2004 04:53 PM
To Much Oil ! What could happen 98viperGTS RT/10 and GTS Discussions 7 05-16-2004 06:38 AM
Help! Has anyone had this happen? Mike 99ACR RT/10 and GTS Discussions 16 05-10-2004 06:06 PM
