Well, as a Christmas present to myself decide to add some bling to the car with Yellow calipers (same as stock just powdercoated), new pad/rotors. I also figured why not add the SS brake lines as well. Started this little project on Thursday.
Well that last part was a stupid call. First after wasting about an hour trying to figure out how to mount the front lines it turns out the parts shipped to me were missing brackets. Called up the supplier and he overnighted them.. OK so start on the back wheels. Got the brackets Friday morning. Hey all is well. Great customer support... Now the kick in the ass. Mounting up the banjo fitting on the drivers front and after torquing to specs I happen to look at it closely. Turns out the damn banjo fitting is NOT WIDE ENOUGH. The copper washers are just spinning and there is no way in hell it will fit. The washers just spin even with the bolt snugged all the way down. Check the bolt length after tightening it down in both the Yellow caliper and the one I took off. Same or in fact in the Yellow caliper it will snug alittle more. Checked this with no banjo fitting. Wanted to make sure it was not a caliper problem. Of course this is the last side.. I thought I was done. I am so pissed to have wasted so much time. And now with the holiday plus my travel I won't get another chance to work on the car for well over a week. What to do now. I have to assume all of them are too narrow so now I get the pleasure of taking all the SS lines BACK OFF and put the stock flex tubing on. I can't trust any of these SS lines. I will wait to hear back from the Supplier and see what he says. Of course by the time I hear back from him I will be done with the project. DAMNIT. |
Who was the supplier? May save some other guys a lot of time and trouble if they know to check their sets 1st if they have the same kit
I hate to release that I until I get a chance to talk to him. However, if you are getting SS brake lines for Christmas PM me and I will tell you who this is from so you can check. I can also tell you how to check real easy before you WASTE freakin several HOURS putting this stuff on.
When I say loose, I mean it is visually loose on the drivers front. I did not bother to check all the others as close since I ASSumed that this stuff was right. Torqued it to spec and thought all is well. I guess the good news is I just happened to see this before I wasted even more time trying to bleed this system. Like I said, if your worried about what you either just got or are about ready to install PM me and I will give you a heads up. |
Sorry that you had a bad day...but, you are not the first in the brake-line-parts-mixup-game...between two Viper friends who live close-by, we have have the wrong parts/mislabeled parts/sets-with-missing-parts shipped multiple times...in fact, too many times to count. Unfortunately, this includes WELL KNOWN manufacturers (both OEM and aftermarket), parts suppliers, and Dodge/Mopar.
A good rule (which I've broken more than once) is to lay ALL of the parts out and do a run through BEFORE going to the garage...but, even then, some problems may not stand out until late in the game, especially for those of us who do this work only occasionally. Fortunately, it will all workout...though it REALLY fries my asp each time it happens to me!!! |
what steve said. unfortunately it happened but im sure its gonna be handled and resolved soon.
hang in there and just throw a wrench or two it'll make ya feel better, trust me. NOTE::not in the direction of any viper. |
Unfortunately for me, this was the first time I have ever installed SS lines. I had assumed it would be a straightforward job. There are some other install problems with these lines that I did not go into on the rear as well. However those have nothing to do with potential for leaks or damage due to functional problems like my current issue.
I did double check all the other stuff and it went on perfectly. Just had a brat, some dill pickle chips and a beer. I guess it is time to start replacing all the SS lines back to stock. Guess I will still be up when Santa arrives. I think I'm gonna eat his cookies tonight. |
On the front passenger side I looked closely at the banjo fitting. It looked good, then I checked to make sure it was torqued down and it was according to factory specs.
I then got a pick to see if I could move the washers and YES they were loose. Not as bad as the drivers front but then again it doesn't matter. I will do the rears tomorrow. If Santa brings you SS lines...PM me. Course I might just be mad enough tomorrow to tell you who it is. By the way in case a supplier of SS lines is reading this you have a voice mail. I send you back your parts, you send me a full refund plus shipping. Even with that then I am only mildly pissed. |
Hey, I have 4 sets of FRONT rotors and 1 rear. Quess why? I feel your pain..... |
ViperBite, the other SAD thing here is that to return to your stock lines, you should really use brand new, correct copper washers for your banjo bolts...hope you have spares. If not, you may get by, but keep the recommendation in mind and order some spare washers.
Merry Christmas, Dude. |
Indy...so far since the current bolts never made contact with the new copper I am ok. There is (was) not a mark on them so the fronts are good. I will find out about the rears tomorrow. I have another post of the banjo bolt issue with a pic, check it out.
Red...how the heck can you have so many sets of rotors? I am keeping my stock set. Only 8000 miles on them, never know when they may come in handy. I will post some pics of my rear brake pads, the inboard pad on both reats was only making contact on 3/4 of the pad. Thanks and Merry Christmas to all. |
If I got 'extremely pissed' every time a parts order was screwed up, or something I bought for my cars didn't fit just right, well, I'd be pissed all the time.
Sereiously, it happens all the time. Deal with it next week and everything will be fine. Jim |
Jim, if your assumption that "everytime" a parts order gets screwed up I get pissed you would find yourself wrong.
Thanks for your help about letting me know I can deal with it next week. Never thought of that. |
Did you try a shorter bolt?
Jim |
First set of Stainless flex lines I did was for my CJ-7. Goodridge DOT correct part, ya right, I had to fabricate all new brackets, hose length was 2" too long (get snagged during compression of suspension). This is why I stick with factory OEM parts, tired of "performance upgrades".
#15 | |
I have KVR cadmium plated and drilled ones, Mopar and who the h3ll knows whatelse. I got pissed too, but a year later I have decided to use them in my Lexus SC400 trunk as weight during winter time. Works great!! |
| Advice re: buying extremely low-mileage Viper | seoross | RT/10 and GTS Discussions | 18 | 08-30-2006 02:04 PM |
| I'm extremely disappointed in the lack of "Copperhead" details or pictures. | jwwiii | SRT10 and SRT10 Coupe Discussions | 5 | 04-27-2005 07:20 AM |
| Extremely Disappointed | Milksnake | SRT10 and SRT10 Coupe Discussions | 10 | 04-25-2003 08:29 PM |
| EXTREMELY DISAPPOINTED IN DEALER/DODGE | VIPERESS | Sneaky Pete's Place | 28 | 03-12-2003 06:44 AM |
| EXTREMELY disappointed with Sean Roe clutch adjustment | 2tall | RT/10 and GTS Discussions | 33 | 01-11-2003 12:39 AM |
