Old 02-01-2006, 06:24 PM   #1
Purdue_Boiler_Viper
Default Jesel 1.7:1 Rocker Arm Install Question
I'm installing Jesel Mohawk rocker arms on my 01 GTS. Instructions are reasonably clear. But, they state: "Set Intake Lash to desired spec." "Set Exhaust lash to spec."
I've looked at the DC Service Manual, and anything else I could find. I do not find a clear "spec".
Anybody have experience on this install?
Thanks,
Pat
Old 02-01-2006, 07:13 PM   #2
Viper Wizard
Viper Wizard's Avatar
Default Re: Jesel 1.7:1 Rocker Arm Install Question
Hey Pat,
I've installed many! At top dead center with the cylinder, turn your adjusting screw to 0 lash and then turn it in/down 1 & 1/2 turns [cold] on intake and exhaust. This will get you in the middle range of the lifter when hot.
Old 02-02-2006, 08:09 AM   #3
Purdue_Boiler_Viper
Thanks Chuck. As always, you are the man.
Harland Sharp Rocker install Mark Hahn RT/10 and GTS Discussions 3 07-20-2006 02:49 PM
Jesel Roller Rocker Clatter at start up Purdue_Boiler_Viper RT/10 and GTS Discussions 4 02-24-2006 06:01 PM
Roller rocker install question MoparMan RT/10 and GTS Discussions 18 11-12-2004 08:30 PM
Jesel rocker pics Simms RT/10 and GTS Discussions 18 09-12-2004 03:41 AM
T&D/Mopar Rocker Install HOdbleFman RT/10 and GTS Discussions 4 08-02-2004 08:04 AM
