Old 02-12-2006, 04:45 PM   #1
DviperX
Default Stock tire milage?
How many miles before your stock tires needed replacement? It appears my treads are good but the handling and spin out is horrible. I have 13,000 miles on them.
DviperX is offline   Reply With Quote
Old 02-12-2006, 04:53 PM   #2
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
Default Re: Stock tire milage?
The spinout and handling may be horrible because the tires are getting old and hard. Sounds like its time to get some new shoes IMO
Old 02-12-2006, 04:56 PM   #3
DviperX
I kind of figured that so I just purchased a new set of Pilots from Tire Rack. Front and back so hopefully that should solve my problems. Thanks for experiance
Old 02-12-2006, 05:00 PM   #4
V10SpeedLuvr
GA VCA President
Since you're replacing all 4 tires, remember now you have an excuse to find a big empty area and do some massive burnouts...that way, you know you need new tires when you're done
Old 02-12-2006, 05:38 PM   #5
DviperX
That is exactly what I was thinking Burn outsssssss
Old 02-12-2006, 05:45 PM   #6
syclone1157
Take a video.
syclone1157 is offline   Reply With Quote
Old 02-12-2006, 05:45 PM   #7
Randy
Randy's Avatar
As already mentioned, the age of the tires directly affects how hard the tires are, etc. New Sport Pilots are quite nice handling and gripping tires. However, old Sport Pilots (or any tire) typically don't grip well, and can be literally dangerous on a high-horsepower car. With that said, I bought my current '00 RT/10 in 2004 with 12k miles on what I assume are the original Sport Pilots. Its now got 28k miles on it, and the rears are down to the wear bars, and its already been a bit dicey at hard cornering or high throttle. Its also darting almost as bad as my old '95 RT with the original XGTZ's and 25k miles did. However, I've not experienced any push or understeer issues, which I would also expect with lessening front-end grip.
As such, I'm thinking about replacing all four tires, despite the fronts still showing a ways to go before the wear bars. I figure tires are cheaper to replace than bodywork if I should indeed lose it.
Old 02-12-2006, 05:53 PM   #8
garolittle
Georgia VCA Member
garolittle's Avatar
I got about 19K miles of the orginal tires on my '01 RT/10. There were getting a little old so I replaced them even though I probably had another 5K miles left.
garolittle is offline   Reply With Quote
Old 02-12-2006, 07:14 PM   #9
Midwest Muscle
I think mine might wear out more due to age than they would mileage. 2,350 miles and counting ...
Mike M
Midwest Muscle is offline   Reply With Quote
Old 02-12-2006, 07:30 PM   #10
GR8_ASP
My experience is 12-15,000 miles or 5 to 6 heat cycles. Whichever occurs first. It is tough to have half tread life remaining when the heat cycles have resulted in tires with no grip.
Old 02-12-2006, 07:48 PM   #11
danalt
I got 14,000 on rear tires and 20,000 on front tires
danalt is offline   Reply With Quote
Old 02-12-2006, 08:27 PM   #12
DodgeViper01
DodgeViper01's Avatar
I find that the average for the rear is around 15,000 and the front about 20,000 but there are expections to this rule. Ask CitySnake, 30K+ on original tires.
Old 02-12-2006, 08:33 PM   #13
AviP
AviP's Avatar
Or me @ 23K. And I'm not at the tail end of the pack either.
Old 02-12-2006, 11:29 PM   #14
V 10 MAFIA
V 10 MAFIA's Avatar
I think City Snake has the record for original tires.
V 10 MAFIA is offline   Reply With Quote
Old 02-13-2006, 07:18 AM   #15
KWIK96
KWIK96's Avatar
50K !!!
Must have done them all on the dyno
KWIK96 is offline   Reply With Quote
Stock wheel & tire. Tire slipping on rim ! PowerKraus RT/10 and GTS Discussions 12 03-13-2006 11:24 AM
Question about the value of a higher milage Gen 1 bth1 RT/10 and GTS Discussions 10 10-03-2005 08:46 AM
Old tire stock of G force Mike Adams New Products, Supplier Specials, and Group Buys 3 07-13-2004 10:38 AM
Anyone have a GTS with higher milage then me? Travis RT/10 and GTS Discussions 6 06-11-2004 05:48 PM
What tire PSi for 1/4 for stock tires? ElDiablo Viper RT/10 and GTS Discussions 5 03-22-2003 03:40 PM
