Old 04-22-2006, 08:20 PM   #1
427Aggie
Texas VCA Member
Default Replacing AC Compressor
OK..compressor is bad..won't take a charge...got the thing unscrewed and unhooked.
HOW THE HELL do you get it out of the engine compartment? I twist..tweak..swear..drink..cuss..and still nothing...It almost looks like I have to take loose a motor mount to get it out..there is just too much crap in the way and it won't get out of there.
HELP!!!!
Matt
427Aggie is offline   Reply With Quote
Old 04-22-2006, 09:09 PM   #2
hemibeep
hemibeep's Avatar
Default Re: Replacing AC Compressor
haven't tried with motor in....but I would try to loosen motor mounts, raise drvr side of motor, then go for it. might be easier to drop out of the bottom with motor raised. If this won't work, I'll check the manual.
hemibeep is offline   Reply With Quote
Old 04-22-2006, 10:21 PM   #3
427Aggie
Texas VCA Member
Ok patience is a virtue I guess...went back out and finally got it in just the right position that it dropped out bottom..new one in already now pan gasket and new belt..
Thanks Hemi.
Matt
Has anyone put AC on a non AC Gen I? I did, the compressor will not come on pattymelt3605 RT/10 and GTS Discussions 14 06-27-2005 10:43 AM
replacing the A/C compressor... ab RT/10 and GTS Discussions 0 08-31-2004 10:53 PM
air compressor v8huntr Sneaky Pete's Place 2 11-10-2002 05:31 PM
Spring Compressor jcaspar1 RT/10 and GTS Discussions 11 11-06-2002 12:34 AM
A/C compressor going? SteveBCloud9 RT/10 and GTS Discussions 0 10-30-2001 04:38 PM
