Old 04-24-2006, 09:52 PM   #1
WANTED
Virginia Maryland VCA Member
WANTED's Avatar
Location: BEL AIR, MARYLAND 2002 R/T GRAPHITE METALLIC TAG: WANTED
Default FIXED TROTTLE STICKING, TRY THIS VERY EASY FIX IF YOU HAVE THE SAME PROBLEM
trottle sticking at 1750 then 1500 then 1000 then 750 idle. i called tom sessions
today as he is the one who gave me the solution. (thanks tom)
if you have this problem as i hear many do, try this.
open fuse box under hood if front of driver. ( by the positive aux battery post )
you will see 9 color fuses, the center one is yellow 20 amp ( pull this fuse it
is marked for the pcm, under the cover that covers the fuses you will see this )
let the car sit for at least 15 minutes then reinstall the fuse. start the car
and give it about 3 minutes as the computer resets itself. this fixed mine.
BY DOING IT THIS WAY YOU DONT HAVE TO DISCONNECT THE BATTERY OR UNPLUG THE WIRE
HARNESS.
i would try this first before messing with the trottle body adjustments.
good luck all, hope this helps others. lmk if it does.
tom
WANTED is offline   Reply With Quote
Old 04-24-2006, 10:16 PM   #2
ViperJohn
Virginia/Maryland VCA Vice President
ViperJohn's Avatar
Default Re: FIXED TROTTLE STICKING, TRY THIS VERY EASY FIX IF YOU HAVE THE SAME PROBLEM
Just a quicker way to do what I told you to do. Glad it worked.
ViperJohn is offline   Reply With Quote
Old 04-24-2006, 10:22 PM   #3
WANTED
WANTED's Avatar
john, i'm sorry. i did call viperjohn first who did give me the solution and
tom sessions gave me the easy way to do it.
THANK YOU BOTH
Old 04-25-2006, 10:34 AM   #4
QUICKV10
QUICKV10's Avatar
Would this also work for different problems. I was just wondering if I should do the same thing for putting new exhaust or any thing else like the intake on, to reset the pcm, thoughts? or should I just leave it be?
QUICKV10 is offline   Reply With Quote
Old 04-25-2006, 01:00 PM   #5
Warfang
Hey... I said to reset your computer from your first post. It worked for me, but the problem came back after a month or so. But I did it by disconnecting the batt. Let us know if the problem comes back.
Warfang is offline   Reply With Quote
Old 04-25-2006, 02:08 PM   #6
AJT
Houston VCA Member
AJT's Avatar
It will come back. All you did was reset the computer.
AJT is offline   Reply With Quote
Has 'heat problem' been fixed on 2008 ? arjay SRT Engineering Q/A Area 3 08-08-2007 01:12 PM
Hesitation problem is FIXED!!! Thanks to Chuck Tator! ArlyDude RT/10 and GTS Discussions 11 01-04-2007 06:00 PM
TROTTLE STICKING - ANYONE EVER HAVE THIS PROBLEM WANTED RT/10 and GTS Discussions 10 04-30-2006 10:23 PM
Fixed my running hot problem - run the AC! AG98RT10 RT/10 and GTS Discussions 3 05-26-2004 06:46 AM
See What's Behind You -- An SRT-10 Problem is Fixed HiYoSilver New Products, Supplier Specials, and Group Buys 1 10-14-2003 10:54 PM
