Old 04-26-2006, 07:17 AM   #1
Nadine UK GTS
Nadine UK GTS's Avatar
Default Hill climb crash and frame damage
This is the same post as on the Alley, so if you've seen it there first no point in reading on (!) but I'm hoping someone can advise re should I do a frame gusset?
After having to replace a broken clutch slave and many other probs (and missing out on booked track days / events) I finally got to get Viper out this year! Just 'limped' back from 3 day event racing in Isle of Man; they closed the public roads on parts of the famous TT-bike course to road race, hill-climb the cars. It was fast, bumpy, narrow, with no run off, dangerous but exciting. Day1, the first race was at night, a steep climb up through the narrow streets and over cross roads to the TT start/finish straight. I was nervous; the odds were on me to set the fastest time of the day! We weren't aloud to do a burn out and had to run street tires, so I spun in the first 3 gears, started to spin a little in 4th too, then the Kumhos started to hook, so I rolled into it some more at about 120mph, we were going blind up over the hill, I knew to keep left for the right turn over the brow, but we got too light over the brow and although I lifted as soon as I felt him start to go, at that speed I wasn't able to catch him. The wheel spin was enough to through us off, and we bounced over the sidewalk and off a concrete wall. The skid marks left behind were 250ft long, and for most of that I was just a passenger. Hay bales were sent high into the air across gardens, but they did help to deflect the car off the wall and lampposts. I was very, very lucky the rear kicked out to the right, as if he'd gone the other way, we would have headed straight at a huge crowd stood behind metal railings; that for sure would not have held back 4000lbs of car at 120mph. I'm gutted over the damage, but lucky the accident was not worse.
Lower front right frame rail's twisted and was hit up splitting the condenser, rad is also leaking. Fog lights gone and passenger side glass was knocked out. Side pipe and 3 of the wheels damaged. Left side of body trashed, and steel door bar brace bent so door wouldn't shut. Worst are both drivers upper and lower front frame rails are bent, crumpled in behind the rearmost front A-arm mounts (car pulling to the left with the left wheel now sitting further back, towing out etc). After checking all out, and much help from others loaning kit, etc, I was able to drive him (many thanks to Joel and also the GT40 club). Although his alignment was shot, due to what it cost me to enter and drive over there, via ferry, I carried on with the event over the next couple of days! Day 2 on the sprint, we were moved to run on the track with the fastest group of cars, as first time out we were overtaking too much, and day 3 I won my class despite taking it 'steady' up apparently the longest and steepest hill climb in the British Isles. All credit to the Viper, we had to drive home too!
Went to see about getting the frame jigged out and straighter, it can be done (when I can afford it for about $1k). But, I'm after advice as I'm worried it's already a weak point (crumple zone holes). I'm thinking of welding in a gusset, to triangulate this area of the lower frame rail to the 90degree rail back from it. It will make accessibility to adjust the suspension cam-bolt tricky, but I think will strengthen the area. (I'd do the gusset, like as done in the 998 recall to strengthen the steering rack mount area.) Have any of you that track your cars done this? I had a look at the GTS-R frame and it's different, much stronger with it's own turret that the A-arm mounts to.
Top of the mountain, there's a big drop over the edge!
Battle scars.
Cup I won, fastest in over 2.0L Sports class. You can see in pic how far back front wheel is from frame getting crumpled.
Little vid Neil's kindly put together, and hosted on VA. First part is a steady siting run at start of Day3 hill climb, then the Day1 hillclimb crash, if link works:
http://[******]/gallery/showphoto.php/photo/25226/cat/509
Nadine UK GTS is offline   Reply With Quote
Old 04-26-2006, 07:30 AM   #2
Neil - UK
UK VCA Member
Neil - UK's Avatar
Default Re: Hill climb crash and frame damage
another link to the vid, captured on a cellular by a spectator
http://www.vipergts.dsl.pipex.com/Nad.wmv
Old 04-26-2006, 08:15 AM   #3
Ricksnake1
WOW! Just saw the video. As bad as the damage is, by your description of the crash, I thought it would be alot worse. Glad your ok and the damage is fixable.
Ricksnake1 is offline   Reply With Quote
Old 04-26-2006, 09:32 AM   #4
Viper Wizard
Viper Wizard's Avatar
Sorry to hear about your mishap with Beloved!
Congrats on winning your class!
"I like the Aquamist stickers on the quarters"
Old 04-26-2006, 09:52 AM   #5
SidewinderGTS
Glad to hear your OK,like you said it could have been alot worse.
Grate job on winning your class.
SidewinderGTS is offline   Reply With Quote
Old 04-26-2006, 10:17 AM   #6
ViperCrazed
I think I would have a few choice words with the guys that was "chuckled" by that...
ViperCrazed is offline   Reply With Quote
Old 04-26-2006, 10:30 AM   #7
Ulysses
I know it was a pain the first time you went through this, but I would bite the bullet and put in a new front section.
Old 04-26-2006, 01:40 PM   #8
BlueGTS
Hats off to you for continuing to race after the accident. Not many people use the Viper for what it was intended for like you do. I know you are going to get it running and looking as good as new. If it takes a month or year it is all good. Glad to see you walked away unhurt.
BlueGTS is offline   Reply With Quote
Old 04-26-2006, 01:44 PM   #9
Lee00blacksilverGTS
VCA President VA/MD/DE
Eastern Zone Director At Large
Lee00blacksilverGTS's Avatar
The frame rails are replaceable. I just went through reearching this issue myself. You will find many that say they are not, but there are a few experts that do it and know how and where to buy the frame rails from Dodge AND how to attach them. One guy I found has done 200 Vipers. Like new they say. Let me know if you would like some phone numbers of the folks I talked to. I know you know Chuck Tator and he probably has sources as well.
Lee00blacksilverGTS is offline   Reply With Quote
Old 04-26-2006, 02:55 PM   #10
ViperDave
UK VCA Member
ViperDave's Avatar
Nad
Sorry to hear about beloved, All credit to carrying on and still winning your class
ViperDave is offline   Reply With Quote
Old 04-26-2006, 04:43 PM   #11
Hoosier Daddy
Hoosier Daddy's Avatar
That side view reminds me of Two Viper Chuck. What determination on your part to continue and succeed! Congrats!!!!
Hoosier Daddy is offline   Reply With Quote
Old 04-26-2006, 05:03 PM   #12
DodgeViper01
DodgeViper01's Avatar
Sorry to hear about that. Glad to hear you are okay though.
Old 04-26-2006, 05:07 PM   #13
Andrew/USPWR
Andrew/USPWR's Avatar
Been there, done that. Glad to hear your all right.
The race looks like a blast though!
Old 04-26-2006, 06:27 PM   #14
Fast Viper Dan
Good job holding on !
Most would have lost it and rolled it over.
Now fix it and get back on grid!
Fast Viper Dan is offline   Reply With Quote
Old 04-26-2006, 06:51 PM   #15
viperdoctor
Just saw the wmv. I'm not in a politically correct mode, so I'll go ahead and say it: You need to get some driving lessons. You drive like a 16yr old boy that is high. The fact that power of the Viper helped you win your class doesn't mean you know what you are doing. You are dangerous.
viperdoctor is offline   Reply With Quote
Frame damage mit RT/10 and GTS Discussions 18 05-14-2005 01:15 PM
Anyone from S.F. Bay area going to Virginia City Hill Climb prodiver RT/10 and GTS Discussions 2 09-10-2002 02:35 PM
Virginia City Hill Climb, Viper Crashes, 2 Dead Tom and Vipers Viper Racing/Dyno Results/Time Slips 10 06-20-2002 12:11 AM
We need Hill Climb RECON @ Sharon Springs, VA Tom and Vipers RT/10 and GTS Discussions 4 06-04-2002 09:53 PM
Virginia City Hill Climb silverviper Archive Management 0 06-11-2001 04:01 PM
