Old 05-10-2006, 11:30 PM   #1
mntngts99
Default Flywheel question
Had to take .015 off my flywheel. Is it good to use or should I get a new one?
mntngts99 is offline   Reply With Quote
Old 05-10-2006, 11:37 PM   #2
trainville
trainville's Avatar
Default Re: Flywheel question
While on the topic, what's the best replacement flywheel to get. My car will be mostly street with an occaisional drag strip use. It has a 200hp wet shot of nitrous.
Aftermarket light flywheel, or OEM replacement???
trainville is offline   Reply With Quote
Old 05-11-2006, 06:34 AM   #3
a-mechanic
FSM says replace.
a-mechanic is offline   Reply With Quote
Old 05-11-2006, 07:31 AM   #4
EllowViper
Central Florida VCA Member
EllowViper's Avatar
Service manual indicates not to turn/true the flywheel...and to replace. I've had many flywheels turned over the years on other lesser cars. Not sure what to make of the service manual procedure. I plan on an aluminum one when I get around to it...
Old 05-11-2006, 10:06 AM   #5
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
When I bought my car, I was given all the receipts the previous owner had. In them was a receipt from a Viper place in NC (where I bought the car) called 2FastVipers. I believe they are closed now, but one of the receipts was for turning the flywheel, and I've had no problems out of mine. I'm not sure when the flywheel was turned, but I've put 10k miles on the car since I bought it.
Old 05-12-2006, 01:50 AM   #6
NWDmax
I'd run it.
NWDmax is offline   Reply With Quote
Old 05-12-2006, 05:06 PM   #7
SNKBYT
NE VCA Member
I took .010 off mine. Installed with a new clutch assembly. Works Fine.
SNKBYT is offline   Reply With Quote
Old 05-12-2006, 05:10 PM   #8
Marv S
VCA Western Zone Director
I like the Comp Coupe Flywheel for SRT Vipers and this one for the Gen 1 & 2 Vipers
http://www4.forum.viperclub.org/show...;Number=660270
Marv S is offline   Reply With Quote
Old 05-13-2006, 10:09 PM   #9
Jack B
Jack B's Avatar
With most hydraulic clutchs there is very limited travel/range, therefore, making any surface removal an iffy choice. You should have no problem finding a good condition take-off, that is probably a better route. As far as what works on the street with pilots could be far different with a set of ET's at the strip.
Old 05-13-2006, 11:05 PM   #10
mntngts99
thanks for the information.
I bought a Fidanza from Roe. If it sucks at the track I'll get another stock one.
Old 05-15-2006, 06:39 AM   #11
a-mechanic
My understanding of the O.E. flywheel is that it is slightly dished, this may or may not be accurate. My instructor at viper class told us this.
Aluminum Flywheel Question TCKTPLZ RT/10 and GTS Discussions 27 05-21-2005 12:11 PM
Lightweight flywheel question MoparMan RT/10 and GTS Discussions 16 12-12-2003 06:39 PM
Question regarding new clutch/flywheel - break-in procedure? XS TORQ RT/10 and GTS Discussions 3 03-18-2003 09:03 PM
Flywheel question Fiorano RT/10 and GTS Discussions 11 12-21-2002 04:24 AM
aluminum flywheel reliability question bigr1 RT/10 and GTS Discussions 8 10-22-2002 06:04 PM
