Old 05-13-2006, 01:36 PM   #1
rx7master
Default creaking popping sound from rear of car?
when im stopped at a light or stopsign and begin to turn into an intersection there will be a strange creaking/popping (like a rapid clunk,clunk,clunk, clunk) sound as i let out the clutch, it only does this when the wheels are turned in either direction and the further the wheel is turned the more severe the sound is. when it is on an incline it does it worse also. along with the sound there is a bit of vibration. it stops completely when the clutch petal is all the way out or if the wheels are staight. did a search with no matches. so i guess its not too common of a problem. im wondering if it could be something with the 998 reacall not being done yet. i have a 1998 gts.
rx7master is offline   Reply With Quote
Old 05-13-2006, 03:04 PM   #2
Ulysses
Default Re: creaking popping sound from rear of car?
Vic from the SoCal VCA had something like this. I think it turned out to be a loose knuckle or something like that in the suspension.
Old 05-13-2006, 04:14 PM   #3
rx7master
is it something that i could fix with limited experience on working on cars?
Old 05-13-2006, 07:59 PM   #4
BruceW
I had a sort of crunching noise when I was turning from a dead stop. Changed my differential oil and it went away. I had about 20,000 miles on the fluid.
BruceW is offline   Reply With Quote
Old 05-13-2006, 08:20 PM   #5
rx7master
yeah, i guess it could be described as a crunching noise, ill try changing my diff oil.
Old 05-13-2006, 10:17 PM   #6
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
If changing the diff oil doesnt get it, jack the car up and retorque every bolt you can get to in the backend. My car used to make a loud bang noise sometimes (but rarely) when 1st taking off from a stop. While the car was jacked up one time, I had the tech retighten all my bolts and he said one on the driver side (some suspension bolt) was definitly loose. Havent heard the noise sense and this was a good few months ago when he tightened them.
Driver side door creaking? moespeeds RT/10 and GTS Discussions 6 01-10-2005 11:01 AM
Exhaust popping sound is it normal? IEATVETS RT/10 and GTS Discussions 12 11-11-2004 12:28 PM
Help Needed with Loud Clunking sound at rear under hard accel???? SF Final 286 RT/10 and GTS Discussions 10 05-29-2004 05:43 PM
Creaking/Popping sound when going into driveway at angle? CMilViper RT/10 and GTS Discussions 8 08-30-2003 06:08 PM
Popping out of gear... SCS Interior and Exterior 5 11-07-2000 11:39 AM
