Old 05-18-2006, 07:37 PM   #1
anton28
Default removing cats.
Im going to be removing catalitic conveters on my 1999 gts. Will i through a code or will it effect the computer? If so what do i need to do to remove them with out any computer issues.
P.S. Smog is not an issue.
thanks guys.
anton28 is offline   Reply With Quote
Old 05-18-2006, 09:08 PM   #2
Snakester
Snakester's Avatar
Default Re: removing cats.
I believe that you need cat sims to keep from getting engine codes.
Old 05-18-2006, 09:36 PM   #3
red98RT10
Hey! I just took out my cats today and was waiting to see if it would throw a code (according to Roe Racing, 1998 and later WILL throw codes), but it did not. Now...I have a VEC 1 and I dialled in a leaner fuel mixture and perhaps that is why it didn't do anything.
By the way, it sounds fantastic! Even from several miles away!!
red98RT10 is offline   Reply With Quote
Old 05-18-2006, 10:15 PM   #4
big-n-italian
IL VCA Member
big-n-italian's Avatar
for the record - i took out the cats on my 97 without adding sims, and did not throw any codes.
big-n-italian is offline   Reply With Quote
Old 05-18-2006, 11:20 PM   #5
mntngts99
Roe S/C, no cats, no sims, no codes.
mntngts99 is offline   Reply With Quote
Old 05-18-2006, 11:43 PM   #6
anton28
i was told of getting sims for the 98+ cars. Even though it might not throw a code it should/will still mess with the fule/air mixture. With the vec-1 you can tune all of that but with the stock computer i might have a problem.
Can anyone recomend where i can get some o2sims?
I high flow cats now and borla exhaust i wonder what it will sound like with no cats.
Old 05-19-2006, 06:35 AM   #7
95Viper
Casper Electronics. They plug right into the OEM connection, no wire cutting.
Old 05-19-2006, 07:12 AM   #8
Mccarlin
Mccarlin's Avatar
I recently removed my cats as well and for 1 week now the car has not thrown an engine code at all (99). it does seem like the car is running rich though as the smell of gas is pretty bad.
Will buying 02 sims (even though i have all my 02 sensors still connected) help any with the air fuel since the cats were deleted? Will i have to remove my 02 sensors for this and replace them with the simms?
Mccarlin is offline   Reply With Quote
Old 05-19-2006, 08:48 AM   #9
SNKEBIT
SNKEBIT's Avatar
The sims are for the rear O2 sensors. The sims will not help the gas smell. A vec.1 will tune out the rich mixture and take away most of the smell. These cars should be tuned w/ a vec. or something similar even if it's stock. They are not tuned very well from the factory.
If anybody needs a vec.1, I might have one for sale here very shortly. With the gauge, complete.
SNKEBIT is offline   Reply With Quote
Old 05-19-2006, 08:56 AM   #10
Mccarlin
Mccarlin's Avatar
How much (if any) horsepower increase can you get from a Vac1 or Vac 2 tuning on a bolt on car?
Old 05-19-2006, 08:57 AM   #11
EllowViper
Central Florida VCA Member
EllowViper's Avatar
Anyone use the mechanical 02 sims...the ones that simply move the 02 sensor anode out of the exhaust stream a bit via bacically a spacer? These only cost a few bucks and theoretically I can see how they would work.
Old 05-19-2006, 10:48 AM   #12
anton28
SNKBIT
isnt the point of the o2 sim to fake the computer to think that the cats are still in place so the air/fule mixture is corect after removing cats.
If not what is the point of getting them.
Old 05-19-2006, 01:27 PM   #13
red98RT10
SNKBIT
that's what I always thought too.
Old 05-19-2006, 06:41 PM   #14
SNKEBIT
SNKEBIT's Avatar
SNKBIT
Yes, that's right. I was just making sure people weren't using the sims in place of the front O2 sensors. With the cats removed, you are now not burning up the "extra" fuel that gets past the cumbustion cycle. (the stuff the cats would normally burn up. hence, why they are so freekin hot) These cars run a little rich from the factory. The vec. will help tune it so you cut back on the fuel load so you won't get such a huge gas smell from exhaust. I have a 94,I prolly gained about 10 h.p. from the vec. You will notice a difference if you have a stock car, I did.
Old 05-19-2006, 07:10 PM   #15
anton28
what is the difrience between Vec1 and Vec2.
Thoughts on Removing Cats Alone? viperbob SRT10 and SRT10 Coupe Discussions 23 11-15-2006 08:23 PM
Removing Secondary Cats??? SRTRICKY SRT10 and SRT10 Coupe Discussions 11 04-11-2005 11:11 AM
Removing cats homesite SRT10 and SRT10 Coupe Discussions 4 07-14-2003 07:17 PM
Removing cats??? Janni RT/10 and GTS Discussions 25 02-23-2002 09:45 PM
removing the cats AviP Archive Management 1 12-30-2000 12:30 AM
