Old 06-07-2006, 02:44 PM   #1
SteveMat
Carolinas VCA Member
SteveMat's Avatar
Default Put in Fram CA8093 Air Filter and 97 GTS runs like crap...
After I installed a Fram CA8093 Air Filter (thought was to replace the K&N's for daily driving), my 97 GTS runs like crap. Not throwing any codes but lots of hesitation, some minor back firing and a minor high idle. I have about 50 miles after the replacement so I assume the computer would have relearned the different air flow?
Thoughts, the only thing I did was swap filters so this was unexpected...
Steve
SteveMat is offline   Reply With Quote
Old 06-07-2006, 02:49 PM   #2
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
Default Re: Put in Fram CA8093 Air Filter and 97 GTS runs like crap...
Go buy some new K&N's (or clean your old ones) and swap back. See if the problem goes away
V10SpeedLuvr is online now   Reply With Quote
Old 06-07-2006, 02:53 PM   #3
sshorty
Where is the mass air sensor on the viper and other intake sensors...did you accidentally touch/move/install incorrectly any of those sensors? Did you seal everything, or is the there a hose left open by mistake? If what I'm saying doesn't make sense cause the car is a speed density car, then im sorry as i am not yet a viper owner...just saying as far as general automotive knowledge goes, this could be a contribution to your problem.
sshorty is offline   Reply With Quote
Old 06-07-2006, 02:53 PM   #4
V10SpeedLuvr
GA VCA President
Also, are you SURE you didnt disconnect any wires to get to the filters before you swapped them out? I dunno about Gen 2's, but on my car, there's a air sensor plugged directly into the airbox and I forgot to plug it back up one day after cleaning my K&N's. That threw my ck. eng light immediately upon crankup, and I remembered I had forgot to reconnect.
Old 06-07-2006, 03:12 PM   #5
Ron
Ron's Avatar
It's not the filters. Put your K&N's back in (without reconnecting any found losse wires) and I'll bet you have the same issue. I use the Fram CA8093's and have no issues. Ran dyno tests on them too. Better than OEM's and in fact bought a lifetime supply.
Old 06-07-2006, 03:57 PM   #6
Mister XR
So what's the deal... fram air filters get more crap out of the air but don't give as much performance? I've been told to avoid fram like the plague, but if it's going to prolong the engine life I'd go for it. This much power is gonna get me into trouble real soon.
Mister XR is offline   Reply With Quote
Old 06-07-2006, 04:00 PM   #7
Silver Snake
I believe this is mostly regarding their oil filters. Never heard anything bad about their air filters though.
Silver Snake is offline   Reply With Quote
Old 06-07-2006, 05:54 PM   #8
SteveMat
SteveMat's Avatar
Given that the getting to the filters is not the easiest thing I thought I may have unplugged something something, I did go through a check any hoses / electrical connecters anywhere near the air box.
Pretty sure everything is still sealed up right, the clips are all attached.
I guess I'll recheck the connectors and maybe put the K&N's back in. I'm guessing I messed something up but was hoping someone else had the samething happen to them (minus leaving something unplugged)...
I'll report back
Old 06-07-2006, 07:48 PM   #9
96GTS
Did you take them out of the wrapper before installing?
Sorry, couldn't resist.
96GTS is offline   Reply With Quote
Old 06-07-2006, 08:54 PM   #10
FE 065
Old 06-08-2006, 08:37 AM   #11
SteveMat
SteveMat's Avatar
That fixed it, I pulled the wrapper that the Fram filters came in out of the air baffle (they really didn't fit so I had them all crumbled up - they really should have that marked on the instructions)
Actually, I pulled everything back off and kept the Fram's in, unplugged/replugged every connector and we are running fine. One of pleats from the Fram had gotten folded back and caught in the airbox so maybe that was making a large leak.
Note, intent of original post was not to imply FRAM filters are bad but more me being lazy and not wanting to pull everything back off to see what I messed up.
Old 06-08-2006, 11:07 AM   #12
Saint_Spinner
Glad everything worked out. I'm kinda curious, did you take her out for a spin yet? Any changes?
Saint_Spinner is offline   Reply With Quote
Old 06-08-2006, 11:21 AM   #13
snampro
snampro's Avatar
I run the Fram filters since I got tired of the K&N's popping airbox clips all the time and haven't had any problems. glad you got it fixed...
Old 06-08-2006, 02:03 PM   #14
SteveMat
SteveMat's Avatar
Yeah, running fine.
Old 06-08-2006, 02:06 PM   #15
V10SpeedLuvr
GA VCA President
I just saw what your tag says Steve. Very cool!
Fram Air Filter Part Number? bwhitmore RT/10 and GTS Discussions 7 11-24-2005 05:55 AM
Anyone use the Fram AirHog? 95Viper RT/10 and GTS Discussions 0 10-12-2005 07:40 AM
K&N Filter Dyno Runs gtsviper SRT10 and SRT10 Coupe Discussions 6 07-19-2004 09:27 AM
Fram - Hog filter 95Viper RT/10 and GTS Discussions 0 04-13-2004 07:10 AM
49/50 State Legal GTS' REDSLED RT/10 and GTS Discussions 4 07-02-2002 07:59 PM
