Old 06-30-2006, 02:28 AM   #1
onerareviper
Default 0158 Code (O2 Sensor Circuit High Voltage) Bank 2 Sensor 2
Viperholics,
I keep throwing this code about every 100 miles. Light stays on until I reset it. Stock headers/new OEM cats/Corsa Exhaust. Is the rear passenger O2 sensor tripping this error code? If so, I may just try to replace them (I have an extra set). Although, they are from a 2001 GTS vs. my 1998 GTS. They are front sensors as well, which I hope are the same as the rears.
Are all 4 O2 sensors the same, and do they vary from 1998-2001? If memory serves, I recall reading that these are all the same.
Thanks.
Old 07-02-2006, 09:37 PM   #2
Jack B
Jack B's Avatar
Default Re: 0158 Code (O2 Sensor Circuit High Voltage) Bank 2 Sensor 2
All the rear sensor does is indicate that the cat is working. I would have someone look at it with a scan tool. You can tell quickly if the sensor is working.
Sensor circuit high voltage OVERBOOST RT/10 and GTS Discussions 2 03-19-2007 02:55 AM
Map sensor Low voltage code vegasviper RT/10 and GTS Discussions 6 03-10-2006 09:18 AM
How to fix Code 52/56 heater control circuit high bank 2 sensor1/2 chex Performance Modifications 3 12-18-2005 12:11 PM
Tricking the Mass Airflow sensor//voltage resistance pauls RT/10 and GTS Discussions 13 03-14-2002 10:11 PM
Bank 2 Sensor 1 (Check engine light) lleone RT/10 and GTS Discussions 3 08-16-2001 04:33 PM
