Old 07-06-2006, 08:22 PM   #1
GTSnake
GTSnake's Avatar
Default Show me your nitrous WOT switch mounting
Can anyone please show me a picture of how you mounted your nitrous switch?
I'm having a hard time figuring out where and how to mount my switch.
Old 07-06-2006, 08:51 PM   #2
Default Re: Show me your nitrous WOT switch mounting
i couldnt figure out how to either. then i realized i can use the VEC2 as one as well as the RPM switch...
there are no good pics of thelocation anywhere from what i saw at the time
plumcrazy is online now   Reply With Quote
Old 07-06-2006, 09:47 PM   #3
2001 GTS
Mine is right behind the throttle linkage, it triggers the switch at about 3/4 throttle.
Old 07-06-2006, 09:59 PM   #4
1TONY1
1TONY1's Avatar
You might check the NX switch that works via the throttle position sensor. I may change from mechanical to that one down the road.
http://www.nitrousexpress.com/Pages/TPS.htm
Or a fancy one that does more:
http://www.nitrousexpress.com/Pages/...ndowSwitch.htm
Old 07-07-2006, 05:19 PM   #5
GTSnake
GTSnake's Avatar
Been there. Tried that. The 5V output is not enough to trigger the relay on a consistent basis. At least not my relay.
Old 07-07-2006, 05:22 PM   #6
GTSnake
GTSnake's Avatar
Thanks Tony but these are a little more than I want to spend. I already have a microswitch that should work. I can't see spending another Franklin just to activate it.
Old 07-07-2006, 09:50 PM   #7
Jack B
Jack B's Avatar
The mechanical switch is always a stretch, our throttle shaft does not lend itself to the samll limit switches. I bought the NX switch and it still sits in the box. If you want it you can have it for 75% of the Summit price.
I ended up using a similar electronic switch from Denny at Racetested, it is a product from Wizards of Nitrous (WON).
The VEC can be used as a window switch, but, you still want the throttle position switch, otherwise you cannot rev at the line, plus, there are other reliability issues with the second switch.
can mounting be a problem? 2snakes4us Tire , Wheel, Brake and Suspension 16 07-06-2007 10:30 AM
Nitrous Bottle Mounting locations? Poolfanatic RT/10 and GTS Discussions 2 10-21-2004 07:48 PM
Any experience with the new NOS TPS progressive Nitrous switch HP Performance Modifications 2 04-30-2003 12:58 PM
rpm window switch for nitrous Scott E. Smith Performance Modifications 8 04-15-2002 12:56 AM
