Old 07-08-2006, 02:56 PM   #1
Edward 96GTS
Default Clear bra on side sill? ok to install or too hot?
Is the side sill temp too hot to install the cear bra material? Will the high temps melt or bubble the material? hate to have the paint and 3m material fuse together.
tia
Edward 96GTS is offline   Reply With Quote
Old 07-08-2006, 03:55 PM   #2
GT40DOC
GT40DOC's Avatar
Default Re: Clear bra on side sill? ok to install or too hot?
If you still have the factory cats, I personally, would not because of the heat. I might expect the clear bra material to "yellow" as does some of the clear coat paint colors. I run the factory cats, but aftermarket mufflers and the muffler area, on my car, would be no problem. The cat area gets awfully hot and I added extra insulation to boot. Of course, I live in an "inferno" for 4 months of the year.
GT40DOC is offline   Reply With Quote
Old 07-08-2006, 11:08 PM   #3
DodgeViper01
DodgeViper01's Avatar
With high flow cats, it looks like it is okay. I had the same question last week.
Old 07-08-2006, 11:27 PM   #4
94RT10Ohio
When I put on my new sills I put on some protectant, but only small areas. Basically the same areas as the stock GEN I sills had from the factory, but better So far so good.
Oh and I do have high flow cats (Roe system).
94RT10Ohio is offline   Reply With Quote
Can you install a clear bra over vinyl stripes? agentf1 RT/10 and GTS Discussions 8 05-01-2007 12:05 AM
GP on Clear Side Markers Inferno RT/10 and GTS Discussions 12 12-30-2005 09:15 PM
Side Sill Insulation for GEN I Side exhaust ViperJames RT/10 and GTS Discussions 5 10-07-2005 04:39 PM
Will there be anyone at VOI that will install the 3M clear Bra? KenricGTS SRT10 and SRT10 Coupe Discussions 9 08-22-2004 02:27 AM
Need Clear Side Markers...? SHADOW RT/10 and GTS Discussions 4 12-06-2003 09:44 PM
