Old 08-01-2006, 08:26 PM   #1
Mopar488
Mopar488's Avatar
Default Maintenance items
I would like to change my fluids w/o having to go to the dealership. I did recently get them to change the oil. I think I need to change the anti freeze, rear differential which has no drain plug, and possibly the transmission fluid. Any body have procedures for the differential and transmission fluid change? I also notice that 3 of my rear oil bolts are seeping and I was told I could put some silicone sealer on them to stop the seepage. They go into the block and the top is open into the pan. I am wondering if I need to drain the oil before taking the affected bolts out. If so, I will wait until I need another oil change.
Mopar488 is offline   Reply With Quote
Old 08-01-2006, 10:08 PM   #2
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
Default Re: Maintenance items
Torque the pan bolts.
Tranny and diff are straightforward.
Tranny - drain plug is on the passenger side rear. Fill plug is on the driver's side front.
Diff is a pain. I think they stopped putting a drain plug in them around 94. You have to get a pump and pull the fluid out of the fill plug. Fill plug is on the passenger side.
You could drill a drain plug in the diff. I drilled one in both my Vipers. Instructions are on this site. I recommend a 1/8 plug, that way if you screw up you can move up to a 1/4 inch plug.
Old 08-02-2006, 08:59 AM   #3
Tom, F&L GoR
Tom, F&L GoR's Avatar
Diff - drill hole through bottom rear cover bolt hole. Then the bolt is the plug.
Radiator maintenance V10SpeedLuvr RT/10 and GTS Discussions 4 11-23-2005 10:37 AM
Maintenance Manual Dixie Snake SRT10 and SRT10 Coupe Discussions 10 09-16-2005 08:10 AM
Maintenance additives? Kiaser RT/10 and GTS Discussions 1 04-27-2005 09:52 PM
After Race Maintenance??? larry milo RT/10 and GTS Discussions 7 04-21-2004 05:43 PM
