I am programming my 2nd Innovate wideband in the passenger bank and I have a question. I am duplicating my setting from the one I installed last year but now I am wondering if I put the correct parameters in. Does this look right?
0.00 Volts = 10.00 AF 5.00 Volts = 17.99 AF I believe I received these settings from Sean but I can not find the email and today is Saturday. I want to test my new 10psi pulley but also want to make sure I am set up correctly. Thanks in advance to anyone who double checks the numbers for me. |
Actually in the WBO you can set the Volt output.
Check the WBO's manual. |
#3 | |
On another note, do you notice that your boost starts ~2psi below its max and works its way to the max boost from a 3k-5k pull? I don't know why but my boost shoots up to about 2psi below its max when I hit it and I gain the additional 2psi as I approach 5500. Have you noticed that on your car? |
| Is the Innovate Digital Wide Band a good choice for GTS | vegasviper | RT/10 and GTS Discussions | 9 | 06-16-2006 04:47 PM |
| Wide band monitor | pedro | RT/10 and GTS Discussions | 9 | 12-30-2005 06:47 PM |
| Wide Band install | pullshard | RT/10 and GTS Discussions | 5 | 08-19-2004 10:39 PM |
| What do you guys think of this wide band 02? | ab | RT/10 and GTS Discussions | 2 | 05-03-2004 11:09 AM |
| What is the best Wide-Band | vegasviper | RT/10 and GTS Discussions | 4 | 12-11-2003 07:51 AM |
