Old 08-13-2006, 12:39 PM   #1
Paolo Castellano
Default 800 RWHP on stock fuel system..... CPE TT
Hello all!
I would like to take this opportunity to share some of the data from the AEM datalogging we have done on John D'Amico's 1997 Gen 2 DIY twin turbo Viper GTS.
I recently put a little bigger turbo on the car with the new air intake system and intercooler setup.
I initially did some AEM datalogging while John D'Amico was driving to monitor the air-fuel ratios with basically the same tune the car had on it before the upgrade.
Rogue GTS, Bill, has done the datalogging this last week while I have been driving.
We basically upped the boost very incrementally and monitored the air to fuel ratios and the car still had enough fuel at almost 10 PSI where we had the boost cut set.
We were confident the car would have enough fuel to run that boost and decided to bring it to the Sound Performance dyno day yesterday and were pleased to put down 796 RWHP and 782 RWTQ on the stock fuel system stock motor, throttle bodies and heads. The only thing this car has on it is my turbo system, T&D's and a boost-a-pump and AEM.
It took about 5 pulls on the dyno to not hit the boost cut since the boost controller solenoid duty cycle was set for 10.0:1 air to fuel ratios.
The car made 735 RWHP on 10.5:1 at 8.5 PSI
When we leaned it out a smidge, it was hitting the 10 PSI boost cut almost instantly.
So, on the 6th run when the car was definitely not as cool as I would have liked, we pulled the #'s you see on the dyno graph.
Paolo Castellano is offline   Reply With Quote
Old 08-13-2006, 01:09 PM   #2
Default Re: 800 RWHP on stock fuel system..... CPE TT
thats crazy paolo. congrats.
how safe is it though on the stock fuel system ?
Old 08-13-2006, 01:16 PM   #3
99 R/T 10
99 R/T 10's Avatar
Using a Boost-a-pump?
Old 08-13-2006, 01:20 PM   #4
Mr Hemi Head
Mr Hemi Head's Avatar
awesome
What is the rwhp when the boost is limited to (?) for cast piston cars.
Mr Hemi Head is offline   Reply With Quote
Old 08-13-2006, 01:22 PM   #5
Paolo Castellano
99 R/T 10, Yes sir!
Old 08-13-2006, 01:28 PM   #6
Paolo Castellano
awesome
Mr Hemi Head, With how conservatively this car is tuned,
I think the 800 RWHP# with C-16 with cast pistons would be safe as I remember reading about some Macedo car with a roe and nitrous making 800 RWHP on cast pistons.
Also a slightly larger turbo than what was on the car would make the same power at lower boost. This would make the fuel pressure drop with the boost climbing to a minimum.
Plum, I datalogged a ton of stuff that would convince you these are safe #'s on the stock fuel system. Please feel free to call me @ 630-878-3907 if you have any questions.
Old 08-13-2006, 01:41 PM   #7
Joseph Dell
Georgia VCA Member
It is good to see someone finally proving the limits of the stock fuel system on a TT!
I've hit it on SC cars but always wondered about TT's.
In theory, 800-825 should be possible w/ a stock fuel system b/c you don't lose that power that drives the SC.
On a ROE, it takes about 80-100rwhp to spin the blower. On a paxton, it takes about 160-200rwhp.
Those are some sick #'s !! nice job!!!
JD
Old 08-13-2006, 02:13 PM   #8
martyb
I can attest this CPE TT runs very well! The looks and performance of Paolo's system is amazing. My little Gen 1 Roe car went home with it's tail between its legs.
Awesome work Paolo!
martyb
martyb is online now   Reply With Quote
Old 08-13-2006, 02:54 PM   #9
Russ M
Stock injectors?
How much fuel pressure do you bump it up to?
Or do you mean with the stock pump?
Russ M is offline   Reply With Quote
Old 08-13-2006, 02:58 PM   #10
Paolo Castellano
Stock injectors?
-Russ
55# injectors/CPE billet rails
stock fuel pump
boost a pump, raises fuel pressure 1 psi per # of boost.
Old 08-13-2006, 03:30 PM   #11
KepRght
KepRght's Avatar
very nice Paolo!
price of the diy kit?
KepRght is offline   Reply With Quote
Old 08-13-2006, 04:44 PM   #12
Casey
Casey's Avatar
Nice job Paolo!
Casey is offline   Reply With Quote
Old 08-13-2006, 05:16 PM   #13
SYNFULL
SYNFULL's Avatar
very nice Paolo!
Ditto- I am planning on going with a s/c because I don't think I can afford a tt. Would like to know what a system goes for.
SYNFULL is offline   Reply With Quote
Old 08-13-2006, 05:23 PM   #14
big-n-italian
IL VCA Member
big-n-italian's Avatar
i got your message about this paolo.
WOW. CONGRATS!
big-n-italian is offline   Reply With Quote
Old 08-13-2006, 06:22 PM   #15
Earl_H
Paolo,
Congrats...Side question: do you ead boost thru the AEM or Boost Controller. If you are using an alternate source, have you noticed that the AEM reads about 1.5lbs less than boost controller/guage?
Earl_H is offline   Reply With Quote
More updates on custom fuel rails by ab! Fuel tails for stock system too! ab RT/10 and GTS Discussions 0 01-13-2007 11:17 PM
Stock tranny & RWHP REDSLED RT/10 and GTS Discussions 5 03-11-2006 08:50 AM
Most RWHP using stock PCM.. VIPER BAZ UK RT/10 and GTS Discussions 2 04-20-2005 12:03 PM
Max RWHP stock fuel pump will support? BLOWNGTS Performance Modifications 14 10-22-2003 02:45 PM
