Old 08-17-2006, 10:22 PM   #1
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Default Which drilled and slotted rotors are the best to get? E-bay?
I'm doing some brake upgrades and adding Tom's 40mm brake kit to my RT/10 so i decided to get some drilled and slotted rotors! I don't want to spend alot and i know some of you have bought these off e-bay. Which are the best to get? Any suggestions?
Heres a few choices....
http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/92-02...spagenameZWD1V
These are diamond cut , does that make any difference?
http://cgi.ebay.com/ebaymotors/Dodge...17150812QQrdZ1
Any suggestions? Anyone have any of these rotors?
JUCD VPR is offline   Reply With Quote
Old 08-18-2006, 01:48 AM   #2
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Default Re: Which drilled and slotted rotors are the best to get? E-bay?
?? Anyone ??
Hmm your all probably sleeping...
Old 08-18-2006, 03:12 AM   #3
Fred(DrivingSchool)Kinder
Slotted and or drilled rotors. Not sure if there is any real benefit to braking.
Lot of theory but pro and con. I would not waste money on slotted or drilled rotors. I have the StopTech Big Brake kit on my ACR, that was a braking improvement.
Old 08-18-2006, 03:17 AM   #4
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
I wasent expecting a big improvement in braking but they look alot better on the car especially when i'll be getting the ccw 505's! Some may call it a poser mod lol.
Old 08-18-2006, 03:43 AM   #5
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Heres another set only 145 bucks...
http://cgi.ebay.com/ebaymotors/92-02...18165936QQrdZ1
I'm going to buy from one of these places, but i'm just not sure if one is better then the other?
Old 08-18-2006, 03:59 AM   #6
FYI one Issue with drilled rotors is cracking around the holes.
If you are buying drilled/slotted rotors for an illusions of high performance rotors then cost vs looks may be the guiding light.
But if you want stopping power use the stock rotors with better brake pads and rotor cooling hardware like air deflectors.
Old 08-18-2006, 04:19 AM   #7
Paul S Lacey
VCA President United Kingdom
Paul S Lacey's Avatar
EBC discs are great got mine from Jon B they are dimpled,so they look just like drilled rotors as the dimples are painted black and are slotted to help brake gas dispersal I do agree with Fred but I could never afford the Stoptech kit for a couple of track events per year.
On the road the EBC's look great.
Paul S Lacey is offline   Reply With Quote
Old 08-18-2006, 04:54 AM   #8
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Yah i heard about that issue. Like i said it is just for street use, not the track. I figure with Tom's 40mm kit, drilled and slotted rotors, and EBC green brake pads i should have alot better stopping performance.
I saw the EBC rotors but they are a bit expensive!
Old 08-18-2006, 05:17 AM   #9
RedEnuf93
PA/WV VCA Member
RedEnuf93's Avatar
I have used last 2-3 years RotorPro's from E-bay. Get zinc plated with painted hubs. Cheap and works well. I dont track the car, but for everyday cruising they are OK.
I change them about every 2 years or so. Not that they are worn, but they tend to develop tiny cracks. No problems with them so far with about 15K miles.
Old 08-18-2006, 08:03 AM   #10
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Rotorpro's? I'll look into them. Thanks
Old 08-18-2006, 08:33 AM   #11
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
I'm going to go with one of these two but i can't decide. give me your opinions...
this one...
Or this one....
Any opinions?
Old 08-18-2006, 02:04 PM   #12
EBS pads are lower dust pads but the trade off is braking performance. The better braking from Tom's 40mm kit is offset with the EBS pads.
Old 08-18-2006, 04:54 PM   #13
Big Medicine
With better braking meaning heat soak; you can still lock the wheels up with ebc greens, just not time and again in short time spans.
Big Medicine is offline   Reply With Quote
Old 08-18-2006, 05:13 PM   #14
2MANYTOYS
Carolinas VCA Member
this one...
Or this one....
I bought the R1's.
Any opinions?
2MANYTOYS is offline   Reply With Quote
Old 08-18-2006, 09:26 PM   #15
JUCD VPR
Gateway VCA Member
JUCD VPR's Avatar
Did you say that you bought the R1's? How do you like them?
NEW Euroteck Motorsports 2pc. Slotted or Drilled and Slotted Rotors! YellowViperSRT10 SRT10 and SRT10 Coupe Discussions 2 05-31-2007 10:53 AM
NEW Euroteck Motorsports 2pc. Slotted or Drilled and Slotted Rotors! YellowViperSRT10 New Products, Supplier Specials, and Group Buys 1 05-31-2007 02:45 AM
Cross Drilled and Slotted Rotors CitySnake RT/10 and GTS Discussions 16 01-02-2006 12:20 PM
Slotted/Cross-drilled Rotors UNRATLD RT/10 and GTS Discussions 18 08-14-2004 08:57 PM
"Rotora" drilled/slotted rotors ??? GoldMan RT/10 and GTS Discussions 1 02-22-2004 09:46 PM
