Old 08-28-2006, 07:38 AM   #1
red98RT10
Default two post lift vs four post
Can anyone tell me the advantages/disadvantages of the two. Everyone I've seen here seems to be getting the four post....but if you are going to do tires, springs, suspension stuff wouldn't a two post be better? I am putting up a new garage and will be using the lift for the Viper but also to restore a classic Mustang. Thanks in advance.
red98RT10 is offline   Reply With Quote
Old 08-28-2006, 07:43 AM   #2
snampro
snampro's Avatar
Default Re: two post lift vs four post
two post gets the weight off the wheels by lifing the frame, four post lifts the car but the car's weight is still on the wheels.
this is exactly why I haven't bought a lift, because I want a two post lift, since you'll still need to jack the car to remove wheels or rotate wheels (on my other cars) with the four post...
Old 08-28-2006, 07:56 AM   #3
red98RT10
anyone have recommendations on a two post? or anyone interested in a group buy for a two post lift?
Old 08-28-2006, 07:58 AM   #4
Ron
Ron's Avatar
There is another alternative, a scissor lift.
Wheels free and great for normal 4" concrete floors and 2,500psi concrete as it spreads the weight over a much larger area. In addition, it's almost invisable as it's 4.5" tall when down, is drive over and has no poles to bang your doors on. Lifts to full 6'7" height and uses foam blocks to contact the frame.
It's not the cheapest solution, is not for undercar storage (like a 4 post) but is a great working lift for a narrow garage bay or for garages with normal floors. Two posts really need >4" concrete and >2,500psi concrete with no expansion joints within 12 inches of the base (as I remember).
Old 08-28-2006, 08:26 AM   #5
RoadiJeff
Gateway VCA Member
RoadiJeff's Avatar
There was a group buy on the Complete Hydraulic lift. Price was under $1,700 and supposedly made in Texas. I couldn't find any negative feedback from VCA members who bought one.
RoadiJeff is offline   Reply With Quote
Old 08-28-2006, 08:34 AM   #6
Drew728
Check out "Bend Pac" 7,000lb scissor lift. Model SP-7X. (bendpac.com)
Drew728 is offline   Reply With Quote
Old 08-28-2006, 09:00 AM   #7
revived_gearhead
revived_gearhead's Avatar
I have the four post lift from Direct Lift with the optional jack that raises the car to suspend the wheels and suspension. In my opinion it is the hot setup. With the 2 post lifts I've looked at, there were issues with getting the lift pads under the car due to how low these Vipers are. Also, during storage, do you want your suspension hanging? Total cost for the lift w/ optional jack and shipping was $2600.00. Tough to beat it. It's also rated for 7000 lbs. Good luck with whatever one you choose.
revived_gearhead is offline   Reply With Quote
Old 08-28-2006, 09:01 AM   #8
Ron
Ron's Avatar
Mine in a Nussbaum Jumbo NT made in Germany (hence the expense):
Brochure Web Link
Old 08-28-2006, 10:36 AM   #9
GR8_ASP
Advantages and disadvantages for both. In general if your primary purpose is storage with some maintenance and mechanical work the 4 post is best. For heavy duty work the 2 post is best. I say get both.
GR8_ASP is online now   Reply With Quote
Old 08-28-2006, 12:16 PM   #10
jeffdai
Virginia Maryland VCA Member
thats what i have been struggling with too. i dont need it for storage as my detached garage is 40x32 and i have an attached garage also, but need one for maintenance, trying to decide between 2 and 4 post myself arghh wish i knew more about them
jeffdai is online now   Reply With Quote
Old 08-28-2006, 12:20 PM   #11
jeffdai
i was looking at the site with the group buy from ab, and they have two post lifts also, maybe we could get a discount on those if we decide to go with the two post, or maybe he could offer either a two or four post so we can choose what we want. Biggest thing i guess i need to know is will the viper work on their two post
Old 08-28-2006, 02:28 PM   #12
RandyS
Central CA VCA Member
RandyS's Avatar
I have a 2 post Bend Pac asymmetric (arms to the rear are longer). It is a little tricky with the viper, but no problems. Mine is a clear floor model, the hose and cables are over head, so you need about 11' of height. As far as the floor goes, I knew where the lift was going before construction. I had 3'X 3'x 12" footings in the floor when they poored it.
Randy
RandyS is offline   Reply With Quote
Old 08-28-2006, 02:55 PM   #13
scottgf
scottgf's Avatar
I have a Rotary 4 post and love it but my main deal was needing storage, then doing some maint. If I didnt need the storage, I would have liked a 2 post, but my floor wouldnt handle it...
I would say first of all don't cheap out on a lift, your car and life is at stake.
I think those sissor style would be ok for brake work and stuff, but would be hard to get a trans. out.
JMHO
Cheers,
scottgf is offline   Reply With Quote
Old 08-28-2006, 03:19 PM   #14
ab
ab's Avatar
On the 4 post lifts, you can do brake work on them. They make several accessories with the 4 post lift. I like the two post, but I think the four is more functional for a home garage type enviroment and also spreads the weight more evenly.
Old 08-28-2006, 03:32 PM   #15
Johann
For maintenance only go with a 2-post, you'll have more clear area to work.
Johann is offline   Reply With Quote
4-post lift for lowered Gen II RX VIPER RT/10 and GTS Discussions 15 03-15-2007 04:44 AM
Who here has a 2 post lift? Casey RT/10 and GTS Discussions 5 10-31-2004 06:02 AM
4 Post Lift Discount - Rotary Revolution Lift Jerry Dobson RT/10 and GTS Discussions 32 07-30-2004 12:46 PM
4 post lift - which to buy?? viper lover RT/10 and GTS Discussions 14 07-27-2004 09:32 PM
Two-post lift Geoff Green Sneaky Pete's Place 0 03-23-2002 01:55 PM
