I was looking through some of the items on Ebay and saw this.
http://cgi.ebay.com/ebaymotors/Dodge...QQcmdZViewItem |
Intersting concept. I am assumin there is a coil inside the airbox to allow for heat exchange. While it would provide cooler air, I wonder how it does with high rpm cfm flow.
I seen it before. I think it was a knock off og Henny guy.
Wierd, so you have to have the AC on all the time to utilize it!?!
Hello 7mpg |
Doesn't the AC turn off above a certain speed?
Seems like a good idea but does not seem like it would work just right?
#7 | |
The AC turns off at WOT.
We're both wrong. Service manual says when TPS is at WOT position, PCM turns off AC relay.
In this case, it seems just when you need it, it is turned off. |
We need someone with a Thermodynamics degree to calculate the efficiency gain from using power to cool the intake in order to make more power. Is this a net gain or net loss.
I'm guessing that the gains would be minimal if any at all or else you would have seen this more often. |
so lets see.
1) you have to use HP to turn the AC motor 2) have a hot AC Condencer in front of your radiator 3) have no AC in the cabin all for slightly cooler intake temps this is worth money how???? there is a reason its on ebay |
#12 | |
#13 | |
Ahhhh.....
But just imagine the power gains if you installed this with Vipair!!! Bill |
Anyone notice the sellers name and location? Could it be DC himself?
| air intake | mercury51 | RT/10 and GTS Discussions | 0 | 05-01-2007 12:44 PM |
| Looking for used "hot air" intake for gen 1 | trainville | RT/10 and GTS Discussions | 2 | 03-16-2005 09:39 PM |
| Lot of oil in intake | Schulmann | RT/10 and GTS Discussions | 1 | 11-25-2004 12:47 PM |
| Hot air intake? | John Johns | RT/10 and GTS Discussions | 3 | 09-02-2004 06:20 AM |
| Intake | SapphireGTS | RT/10 and GTS Discussions | 0 | 08-21-2001 11:16 PM |
