I just installed a Mopar performance computer and went for a test drive. My Innovate wideband was working fine for about a mile or so. Then suddenly started reading 20.1 and stayed there. I cut off the engine and turned it back on. It does its initial cycling and then goes right back to 20.1 regardless of whether the engine is on or off??? O2 sensor gone bad? Does the Mopar PCM screw it up somehow or is this a coincident? Ideas?
Thanks! |
The sensor is bad. Replace. Nothing to do with the pcm. Just like I told you before when you asked.
Also, check the wiring to the WBo2 sensor. I had a similar problem that was a cooked cable to the sensor.
ok, new symptom...After the car cools down, it starts working again. Heats up again = "20.1" solid reading again. The cooked wire idea is possible. I'll check that out tomorrow. Definitely heat related I guess. Just put on baby watch duty, fun is over for the day!
all O2 sensors in these cars have to "heat up". so when the car is just being started, before the O2 is warmed up, it might act more normal... but normal operation isn't until the O2 sensor is "warm".
probably the sensor. i'd check that again. JD |
The Innovate set up is a little different, the heater circuit locks out the reading till the heater gets the O2 up to temp. If you are reading 20.9 that means it is reading pure air, that is the oxygen content of mother earth.
Try to recalibrate again. Where is the sensor located. |
#7 | |
In the Innovate LM programmer it should allow you to change the sensor input to a 0-5V analog, that will give you an an idea of how the sensor is working. In other words, log voltage, not a/f.
The strange part is the install proximity of the new pcm to the bogus reading. If you are worried you can also use a scan tool and check the volatge on the oem O2 sensors. It should be rapidly changing in the 0-1 volt range. Joe is probably right and it is the Innovate sensor or associated wiring, you would have set a PO17X code if it was running lean under load. |
| INNOVATE LC-1 to Vec set-up question | DAMN YANKEE | RT/10 and GTS Discussions | 13 | 04-27-2007 07:51 AM |
| anyone have an innovate LC1 wideband they didnt install or use ? | plumcrazy | RT/10 and GTS Discussions | 1 | 04-08-2007 04:12 AM |
| Help with Wideband-to-VEC2 logging (Innovate wideband) | Irid | RT/10 and GTS Discussions | 2 | 02-26-2006 08:36 AM |
| Innovate LM-1 wideband O2 sensor w/datalogging | Go Fast For Life | Performance Modifications | 32 | 10-22-2004 07:23 PM |
| Innovate Motorsports Digital Wideband 02 | Larry Macedo | New Products and Supplier Specials | 4 | 01-19-2004 04:25 PM |
