Old 10-14-2006, 05:36 PM   #1
OKViper
OKViper's Avatar
Default MUST READ - GTS Dyno Comparison
Hey all,
I made the title "must read" because of the dramatic difference in power that my 99 GTS has recently made...
The car is a 99 with Henn. headers, high-flow cats and Borla cat-back, 1.7 T&D RR's, 65mm TB's and K&N. Last month I posted a dyno sheet and was dissappointed with the power. Here it is:
Here's the good news: I changed my wires (with ab's quality wires) and he added Champion plugs and I redyno'ed. I immediately felt the difference! Remember, NOTHING else was done to the car and it was the same dyno, same weather, same tester:
That's right - Nothing but a wire and plug change = ~30 RWHP and ~35 RWTQ!!!
I checked with the tester and was told that with the "sniffer" that the A/F is consistenly .5-.6 lean, so my ratio is fine and the car runs SIGNIFICANTLY better. Better throttle response and obviously more power.
FYI- My stock plugs looked fine and the wires looked 100%, so without the help of you guys on this forum I would have never suspected that to be the issue. Also, thanks to Terry MacDonald (Viper Tech) in OKC for his service and to Adam for quickly providing a very quality product (he sent them to me before I even sent payment).
Now, this car runs strong - so, I HIGHLY suggest getting these wires and changing your plugs from stock - this dyno tells the tale.
OKViper is offline   Reply With Quote
Old 10-14-2006, 06:28 PM   #2
Casey
Casey's Avatar
Default Re: MUST READ - GTS Dyno Comparison
Good news!!
Casey is offline   Reply With Quote
Old 10-14-2006, 07:08 PM   #3
2MANYTOYS
Good news!! AB is a quality guy. Glad your car is running better.
2MANYTOYS is offline   Reply With Quote
Old 10-14-2006, 07:38 PM   #4
Mccarlin
Sweet numbers...
Those AB wires are GREAT. I love my set.
Mccarlin is offline   Reply With Quote
Old 10-14-2006, 08:40 PM   #5
SnakeBitten
Dont Gen II dyno between 415-420rwhp? Shouldnt he be making more than 441rwhp with those mods?
SnakeBitten is offline   Reply With Quote
Old 10-14-2006, 11:44 PM   #6
SSSSE YA
California VCA Member
SSSSE YA's Avatar
Got to love free HP..
SSSSE YA is offline   Reply With Quote
Old 10-15-2006, 06:41 AM   #7
so AB's wires are good for ~30 RWHP and ~35 RWTQ
way to go AB
Old 10-15-2006, 07:06 AM   #8
PatentLaw
NJ VCA Member
PatentLaw's Avatar
Congratulations. I think that you did the right thing by testing with ONLY the sparks and wires changed out. Gives a great comparison. Does not muck up the results. That is a fairly hefty increase. Perhaps those with 99 and previous year Vipers will start to consider a switch.
PatentLaw is offline   Reply With Quote
Old 10-15-2006, 07:08 AM   #9
Mccarlin
Ive always seen between 390-410rwhp bone stock.
Old 10-15-2006, 07:21 AM   #10
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
I think dynos are like dragstrips, you can run 11.8 at one and then go to another one on another day and run .5 slower/faster.
My 98 dyno'd at 424 bone.
Old 10-15-2006, 08:16 PM   #11
OKViper
OKViper's Avatar
I had a couple PM's so, for others: Car had under 10,000 miles and it ran fine with no "hiccups" before.
I would have never known to change wires/plugs if it wasn't suggested...
Old 10-16-2006, 08:34 AM   #12
ab
Site Supporter
ab's Avatar
I'm glad my wires worked out for you! WOW! big HP gain!
www.qualitywires.com
Thanks again! Many SOLD!
Old 10-16-2006, 08:39 PM   #13
OKViper
OKViper's Avatar
You're welcome for the Kudos - thanks for the fast service and quality product.
Old 10-16-2006, 10:49 PM   #14
viper spray
Told ya..........
http://www.[*****]/forum/viper-discussions-gen-i/48255-gts-dyno-please-help.html
viper spray is offline   Reply With Quote
Old 10-16-2006, 10:52 PM   #15
FE 065
But there was no test to compare new OE wires to AB wires. That's a lot of HP from a wire change. I'd think the ones he had on to begin with were suspect..
Speaking of things in that area..I did change plugs a few weeks ago rounding up 3 sets from local establishments, choosing the ones that indexed in perfectly with the ground electrode pointing straight down and the gap pointing straight up. Then returned the ones I didn't want.
I was careful with all the boxes and plugs, so no harm was done, and I got to choose the ones I wanted.
Old 10-16-2006, 11:20 PM   #16
ruckdr
WA VCA Member
ruckdr's Avatar
What plug gap did you use??
.033, .034, .035, .036 ??
Thanks,
ruckdr is offline   Reply With Quote
Old 10-17-2006, 12:31 PM   #17
IEATVETS
Illinois VCA Member
IEATVETS's Avatar
How does adding new plugs and wires change the HP/TQ? I have heard of this before but never found out how this happens.
Old 10-17-2006, 07:17 PM   #18
OKViper
OKViper's Avatar
Thanks,
I gapped them all to .035 - hope that helps!
RSI 76 GTS TT vs. RSI GT35R (63 mm with 1.06 a/r) TT Dyno Comparison houstonT RT/10 and GTS Discussions 17 04-14-2006 08:20 AM
TNT nitrous dyno run.....graph looks similar to 2001 GTS'..... kwkshift RT/10 and GTS Discussions 19 02-08-2006 09:34 PM
My Dyno Sheet from last night- Read my reply to Corvette Forum BLKSNAKE SRT10 and SRT10 Coupe Discussions 2 11-20-2005 07:40 AM
Is your Dyno lying? Read this tech article from Car and Driver viper spray RT/10 and GTS Discussions 6 04-30-2004 04:18 AM
49/50 State Legal GTS' REDSLED RT/10 and GTS Discussions 4 07-02-2002 07:59 PM
