Old 02-26-2007, 08:38 PM   #1
ViperJames
ViperJames's Avatar
Default Last 300 Side Exhaust
My 95 is stamped under the hood as "last 300 side exhaust". Does anyone know how to find out what # out of the 300 I have and if so does this really mean anything? Thanks.
ViperJames is offline   Reply With Quote
Old 02-26-2007, 09:45 PM   #2
carguy07
carguy07's Avatar
Default Re: Last 300 Side Exhaust
I have a last 300 car too. No one seems to care right now. I would bet it means something in 10 years or so.
carguy07 is offline   Reply With Quote
Old 02-26-2007, 10:13 PM   #3
DodgeViper01
DodgeViper01's Avatar
I did not know that was put on the car. Pretty neat.
Old 02-27-2007, 11:17 AM   #4
Big E
Big E's Avatar
Seems like first and last editions are always worth a little more. But only after the car survives about 35 years or so.......
Big E is offline   Reply With Quote
Old 02-27-2007, 12:09 PM   #5
Bonkers
Unfortunatly only a select few cars were sequenced during build (92s,
GT2s, FEs, VOI9s) all the other vipers were built, sent to a
warehouse/staging area where they were mixed up, and then assigned
randomly issued VIN#s. The only real way to tell is if you get all
the build stickers from all the other Last 300s and use the time to
figure out which came offline first/last. And that's still a crap
shoot.
Bonkers is offline   Reply With Quote
Old 02-27-2007, 04:20 PM   #6
GR8_ASP
Bonkers knows the auto business and how VINs are applied. Not!
In a general sense the VIN does indicate the build order for the production facility. They are created in order at the time of order proccessing called gate line. That is generally about 2 weeks prior to start of framing, to allow all parts to be ordered (JIT components). Beyond that things like options (at the time a/c, Canadian, BUX, color, etc.) could impact where within the build schedule it ends up. That is what causes the VINs to be mixed up.
VINs are assigned BEFORE the vehicle is built, not after, and certainly not after warehousing. Considering the VIN is located in several areas of a vehicle could you imagine a process where it is applied after assembly?
Now as to the Last 300 pin stamp. I was at the plant watching my 1995 get built when they were first starting the pin stamp. It was an idea the plant had due to an extra VIN stamp machine that was no longer needed. This was at Mack Ave Assy prior to the move to CAAP. So they adjusted it to say "Last 300 Side Exhaust" and applied it to the last 300 cars. Those were the cars that were built during the build-out phase, or the last 300 of the model year.
Now as to a secret (not deeply held though). When they were trying out the pin stamp they tried it out on one of the poles that stood along the assembly. line. When Vipers moved to CAAP that pole was moved also. Next time you are at CAAP see if you can find it! It still has the pin stamp clearly imprinted.
Here is a picture of the infamous pole (and a friend of mine pointing towardthe stamp location)
Old 02-27-2007, 04:29 PM   #7
Bill B
FL VCA Member
Bill B's Avatar
I saw it while at both facility's.
Bill B is offline   Reply With Quote
Old 02-27-2007, 07:16 PM   #8
ViperJames
ViperJames's Avatar
VERY INTERESTING! THANK YOU.
Old 02-27-2007, 07:46 PM   #9
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
I knew the last 300 were stamped, but have never known where. Where under the hood is the stamp?
Old 02-27-2007, 07:48 PM   #10
GR8_ASP
Toe box on the passenger side near the heater control valve
Old 02-27-2007, 09:34 PM   #11
Lawrenzo
Socal VCA Member
Lawrenzo's Avatar
If it does, you just know some jokers will find a way to "modify" their cars to get more $ at Barrett Jackson 2025! I bet there will be 400 of these "last 300" running around by then
Lawrenzo is offline   Reply With Quote
Old 02-28-2007, 11:54 AM   #12
redtanrt10
So Cal VCA Member
redtanrt10's Avatar
From memory I thought they're stamped in two places? Your car is unique compared to the other '95's but who knows what it would be worth in the future? I'd rather buy one of the last 300's if I was looking at a '95 if both cars were equal. With the return of side pipes the good news is no one paid stupid $'s for them like they did with the last convertible vette's of '75
redtanrt10 is offline   Reply With Quote
Old 02-28-2007, 08:38 PM   #13
carguy07
carguy07's Avatar
Anyone know where the 2nd place is??
Old 02-28-2007, 09:45 PM   #14
NHL2133
According to the Registry they are only stamped in one place.
"Last 300 cars made at New Mack pin stamped near passenger side window pillar on foot box 'Last 300 side exhaust'"
NHL2133 is offline   Reply With Quote
Old 03-01-2007, 12:54 PM   #15
Mr B
Josh is right, again!
Mr B is offline   Reply With Quote
99 GTS Side Exhaust 71pilot RT/10 and GTS Discussions 8 11-03-2005 04:08 PM
Side Sill Insulation for GEN I Side exhaust ViperJames RT/10 and GTS Discussions 5 10-07-2005 04:39 PM
Side exhaust pipe covers with rear exhaust pipes ??? FLX109 RT/10 and GTS Discussions 19 02-16-2004 04:47 PM
Gen I Roe Side Exhaust 1RT2NV Performance Modifications 1 07-27-2003 01:08 AM
last 300 side exhaust opnwide Archive Management 2 03-06-2001 09:18 AM
