I'm about to put on some B&B headers on and noticed the deletion of the flex pipe.
When the motor torques...where is the flex now? Do the headers take the brunt of the motor movement? |
When I installed my Belenger headers I bought a 3" flex pipe from Summit and installed it.
I am also going to install a new exhaust/muffler setup and had the exact same question.
So I assume that from GTSPOWERED's reply that it is recommended? Please confirm. Cheers GTSjbud |
Your motor shouldn't move that much unless you have a worn motor mount.
Belanger headers for the last 6 years / almost 60,000 miles. No flex pipe--no problems at all.
Steve |
Ok...sounds good. I just replaced my motor mounts last summer, so I should be good.
Thanks |
note to self...change motor mounts
Assuming the GenII hangers are the same as GenI, just don't bolt up the hangers near the front of the side sills. I originally did bolt those up, that didn't leave enough flex in the system, and I ripped the hangers off the exhaust pipe (leaving a nice hole in the exhaust pipe too).
#9 | |
Cheers GTSjbud |
gonna do homework on what one to use. but im installing a S/C and headers with no flex pipe, so id rather be safe.
#11 | |
How much of an issue are the front exhaust mounts?
Anyone else break the hangers off? |
Yes, one of the brackets broke through the stainless steel exhaust pipe right at the weld joint.
I assume that there was to much torque and twisted the hanger which in turn broke through the pipe. |
#14 | |
Steve |
What are B&B headers made of?
| Removing flex pipe from stock header??? | 96 B&W GTS | RT/10 and GTS Discussions | 1 | 03-22-2007 12:56 AM |
| Stock flex-pipe needed, preferably with the stock cats attached | Steamroller | RT/10 and GTS Discussions | 7 | 03-08-2005 08:02 AM |
| Side pipe exhaust and headers??? | Gottaviper | Performance Modifications | 9 | 06-09-2004 12:14 PM |
| Has anyone seen the inside of their stock flex pipe? I was surprised | ab | RT/10 and GTS Discussions | 2 | 05-20-2004 08:03 AM |
| Flex Pipe after Headers? | HOdbleFman | RT/10 and GTS Discussions | 2 | 03-02-2004 11:58 AM |
