Old 03-09-2007, 05:20 AM   #1
viprvenm
Washington VCA Member
viprvenm's Avatar
Default Need Advice/Help - Clutch Issue
Within the last two weeks I have noticed when I start the Viper and start to drive the clutch is more difficult to push in and it engages very close to the floor. It is also more difficult to get into the gears. When the car warms it becomes easier to push in and it will engage a bit further from the floor (what I think to be in a normal position.) This has not been an issue until very recently. Any ideas of what may be going on?
Jason
viprvenm is offline   Reply With Quote
Old 03-09-2007, 05:30 AM   #2
InjectTheVenom
NY/CT Associate Member
InjectTheVenom's Avatar
Default Re: Need Advice/Help - Clutch Issue
Sounds like a throw-out bearing about to bust or maybe a pressure plate, do you also hear a whining noise when you step on the clutch and then nothing when you put it in neutral again?
InjectTheVenom is offline   Reply With Quote
Old 03-09-2007, 06:20 AM   #3
Tom, F&L GoR
Tom, F&L GoR's Avatar
The less scary thing is that you are low on fluid. Check the hydraulic reservoir and add brake fluid if needed.
Old 03-09-2007, 06:08 PM   #4
viprvenm
viprvenm's Avatar
I do not hear a whining noise, but will check the fluid.
Clutch issue John Johns RT/10 and GTS Discussions 2 08-14-2005 09:19 PM
Clutch Issue Question DViper SRT10 and SRT10 Coupe Discussions 10 03-17-2005 02:30 AM
Need Dealer Repair Issue Advice vipah RT/10 and GTS Discussions 1 10-13-2004 12:40 PM
Clutch issue... AG98RT10 RT/10 and GTS Discussions 1 07-23-2004 06:52 PM
I need serious advice regarding titling issue -> artman RT/10 and GTS Discussions 22 04-10-2002 07:01 AM
